Several Problems
Threaded View
New to DSL. I have a network. Wired and wireless with three computers.
I am having a problem that I can't seem to microsoft update, HP printer
software update and sometimes connecting to the POP server to receive
email.
The DSL modem is connected to my Linksys router set as DHCP. All
computers see ea other. The All in one HP print server works great on
the network, we can exchange files, etc. but not windows updates. The
browser just hangs.  All computers are running WinXP.
POP hangs. Not a problem when I had cable.
Any clues?
Fabio
Re: Several Problems
That does not give all information needed.
Which protocol is used on DSL side? PPPoE?
Then it might be a problem with the MTU settings (in the router).
PPPoE needs another 8 Bytes of the header.
So the optimum value normally is 1492.
If it is set to higher values it is possible that some connections do
not work correctly.
Maybe you hadn't PPPoE there.
Wolfgang
well, these are very common problems that one faces when usein g a dsl
connection, esp. with the pppoe/pppoa.
you simplly need to do two things as far as i understand:
1. Replace your USB modem (if thats the one you are using) with a
bridge that
works with an ethernet cable, then set in static ip
addresses for the bridge's
management (instead of dhcp). Please note
that the bridge will get assigned an
ip address from your isp/telecom
operator, static ip is for the routers
management that happens to lie
in your subnet.
2.Set DNS addresses(provided to you by your isp) statically.
3.Also dsl Routers/modems have a special led "xdsl" that glows up as
soon as the
RJ11 cable is plugged in. Please make sure that the led
glows all the time and
shouldnt be in the blinking state (except for
initial sync. and data transfers).
If the "xdsl" LED is blinking check
physical connections . Also see whether you
are using the
splitter/filter provided by your isp in case the telepone/fax is
in use
simultaneously with the internet service.
This will indeed solve all your problems !! and if it doesnt --- check
your
local network !!
----bakerjay----
bakerjay
fabio.soto@gmail.com writes:
Try another modem for comparison.
Site Timeline
