Router vs. Telco DSL Quality Stats
We have been having an on-going battle with several local telcos over DSL line quality. For some reason their testers always show a much higher line quality than does the routers.
For example, I have taken the exact same DSL POTS cable, and plugged it into a Cisco 827, 837, and 877 router and got essentially the same line quality stats. When the local telco test the line (usually using a SunSet MTT test set), they consistently see a good quality line, where the routers see a marginal line -- one that keeps dropping. (And this is not just a single line at a single location -- we have the same problem at multiple locations, and at some locations, on multiple lines at that location.)
For example, here is what the router reports: ATU-R (DS) ATU-C (US) Capacity Used: 98% 53% Noise Margin: 5.0 dB 12.0 dB Output Power: 17.0 dBm 8.0 dBm Attenuation: 64.0 dB 31.5 dB Interleave Fast Interleave Fast Speed (kbps): 1216 0
256 0
and the test set reports:
Capacity: 47% / 40% SNR: 8.5dB / 15dB Attenuation: 40dB / 28dB kbps: 1472 / 256 (noise profile)
Why such a substantial disagreement between telco test sets and Cisco routers? Especially when there is no difference between the wiring to the device, up to and including the cable plugged into the device.
This is getting to be a real pain. We have flaky connections and numerous drops, yet the telco says everything is fantastic. It just doesn't make sense.
TIA for any insights into this problem.
Jon K.
Jon.R.Kibler
The telcos are lying to save money. Escalate the complaint.
LouB
you should check that you have the latest DSL firmware loaded
see Cisco doc "IOS Software Release-to-DSL Firmware Version Mapping on Cisco Access Routers"
Merv
There are free ftp downloads of firmware for the 8[57]7. ftp://ftp.cisco.com/pub/access/800
I have found them to be useful in a number of cases but since the IOS bundled firmware went to 3.x I have not bothered.
Certainly with the 857 and 877 I have seen numerous issues that firmware changes have resolved.
This has been in the UK.
Bod43
Thanks to all. I will try some firmware upgrades this weekend.
I guess that leaves me with the question of how the firmware can effect apparent line quality? It seems that line quality should be independent of the chipset/firmware used. Can someone please explain this?
Again, THANKS!
Jon Kibler
Jon.R.Kibler
If your DSL vendor has a list of recomended modems follow that or you are on your own!
Not all combinations chipset/firmware work equaly well.
When my local telco do a full test they are testing at all cable lengths in 50meter(150feet) incriments. And they have found "funny" bugs. /hjj
Hans Jørgen
wrote
If we forget for the moment that the term "line quality" is itself somewhat ambiguous...........
The chipset/firmware may not be capable of making full use of a "good" line. Or there may be "glitches" in the good line. Or the equipment at your end might not be fully compatible with what the ISP has at his end. Or the equipment at your end might just be "bad".
Not too complicated really.
And to echo a previous post: If you insist on using equipment that is not on your ISPs approved list, then you're on your own.......and it doesn't sound like you are qualified to take up that challenge.
Who Me?
On Wed, 2 Apr 2008 11:30:16 -0700 (PDT), snipped-for-privacy@gmail.com put finger to keyboard and composed:
Apart from the downstream attentuation, it seems that your two sets of readings are within agreement, there being a consistent 3.5dB difference which I suspect may reflect different refence points (?). The big 64dB versus 40dB discrepancy is a worry, though. Could there be a 24dB loss within your premises? (but wouldn't that affect the output power also???)
FWIW, here is my ISP's explanation as to factors that may affect performance:
There is also a "how fast can it be?" graph that charts speed versus attenuation.
- Franc Zabkar
Franc Zabkar
