Problems with bonding 2 x SHDSL lines using MLPPP and CISCO1721
We seem to be having problems with setting up bonding 2 SHDSL 1Mb lines
using a CISCO1721 w/ WIC-SHDSL-V2. But it doesn't seem to be working. When we enable both the lines, the service just drops. Our ISP is Freedom to Surf (F2S) and BT is the wholesale provider. We have spoken to F2S and they say that some of the BT exchanges are not set up to support DSL MLPPP. Does anyone have similar experiences or ideas for a solution?
any thoughts would be grateful
Rgds
Phil
Phil Bartlett
Units in both ends need to use same Bonding type
"Phil Bartlett" skrev i melding news: snipped-for-privacy@f14g2000cwb.googlegroups.com...
Erik Semey
We have had exactly that and opened a TAC case. Normally if the lines are ordered at the same time they go through the same DSLAM etc and timing is OK, but in our case the timing fails.
Solution was to avoid MLPPP and uase either multi Home NAT or load sharing with 2 routes
G
Gary
Well it seems finally Freedom 2 Surf have managed to provide us with 2 x 1Mbs lines bundled together. After plenty of emails/phone calls to and fro them and BT have made the changes to the DSLAM and their network. WEYHEY!!
Phil Bartlett wrote:
Phil Bartlett
