Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on March 9, 2006, 5:36 pm
Please log in for more thread options Signed up w verizon dsl(14.95 package) 'dsl light' on westell modem does not stay on , flickers on and off. Verizon says my completion date is 3-14-06 then why does it say connected 100MBPS icon in system tray when connected? Do I really have to wait to this date? Can someone please tell me how to config this manually without using cd? When I doubleclick on IE it says proxy detected, but I can't bring up any webpages. win xp pro 512 ram dell latitude Thank you. | |||||||||||||||||||||||||||||||
Posted by Cyrus Afzali on March 9, 2006, 6:15 pm
Please log in for more thread options On 9 Mar 2006 14:36:41 -0800, gogetitnow2005@yahoo.com wrote: You're getting a little confused here. The 100 mbps reading you're getting is the Ethernet connection established between your computer and the device. It has no bearing on your DSL connection. I had Verizon DSL in the very early days when it was still problematic, and dumped it for cable and never looked back. But IIRC, there's a "link" light on the Westell modem that should be on and not blinking if you've got a valid connection to your central office. Another sure-fire way to tell if you're DSL is connected is to test your phone. If DSL is active on it, you'll get a "wave-like" effect where the volume will rise and lower until you install the filters on the jacks that are going to service your phone/answering machine, etc. Just make sure NOT to put one on a jack that's going to service the computer. | |||||||||||||||||||||||||||||||
Posted by on March 9, 2006, 7:00 pm
Thanks for your reply. The light flickers on and off(the dsl light) so I guess that the service will not be active until the 14th. On that date, do I have to logon to the router? Do I have to setup a username and pword? I hope all this trouble is worth it; the 768kbps upload seems kind of slow. | |||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| need help w verixon dsl | March 9, 2006, 5:36 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>webpages.
>win xp pro
>512 ram
>dell latitude
>Thank you.
