Date: Wed, 28 Sep 2005 19:56:50 +0100
> Im wondering is it possible to have two different broadband =-
> connections-
> using one phone line in one house? I dont wanna use a wireless router
> to share connections.-
> I never heard of that working. But you can use Home PNA on the same =
> phone line as DSL. As it using an existing phone line as a networking > =
> bus. Thus no need for wireless. By the way, can I ask why you don't > want =
> to go wireless? Security perhaps? If so, WPA encryption is pretty tough > =
> to hack into.
> --=20
> Cheers!
> ______________________________________________
> Bill (using a HP 8655c & Windows 2000)
> --- written and edited with Outlook Express v6.00.2800.1123
I dont want to go wireless because my brother constantly downloading, and it effects the speed of it when i share the connections from it using a router. I was thinking one broadband for working and one for entertainment such as downloading and playing online PS2 games. So is there any possible ways of using two seperate broadband with one phone line, if not, could you tell me why its not possible to do so. Thx!
In a word, no. For the same reason that pigs can't fly. It just doesn't work that way.
More specifically, nobody has yet designed any equipment that will do that. The current equipment uses all of the available bandwidth for just one line. It is possible, however, that newly discovered technology might make that possible in the future. IMHO, that is not likely because I think there would be a VERY limited market since a router works just fine in most situations.
You probably could get your provider to bring in a second DSL, maybe even without a second "voice" line.
Well, yes, it can. But if he's constantly downloading at full bandwidth, I'll expect him to attract some very unpleasant attention from your ISP. But this is unusual, and even then only slows things down ~2x.
It's uploading that causes more trouble, more of the time. A single unthrottled P2P filesharer can just hose out the connection (Very high latency). Downloads stop even when there's plenty of bandwidth because the ACKs can't get through. A known problem on asymmetric links, and the easiest solution is throttling upstream.
You cannot put 2 DSL circuits on one phoneline. No can do: the frequencies are used by the first. But you can put two DSL circuits on two different phone lines. Then you need a rather fancier router, but fortunately you can roll-your own with the Linux Router Project.
You will need to build and maintain routing tables that shovel all the "entertainment" packets (by port and or addr) out one interface.
