Correct. One of the biggest problems I've seen with DSL installations is the condition of the premises wiring, between the telco interface and the various wall jacks. Over the years, splices and taps get added in walls, many of questionable quality. If you depend on locating every telephone device and installing a filter on every one, one day, someone will find a forgotten jack and plug a phone in there, without a filter.
The best practice I've seen is to install a tap just after the telco interface and run that as a single run to a dedicated DSL outlet. Then, immediately following that tap, install the DSL filter and feed the existing premises circuit(s) from the output of that.
The interesting analysis in this case would be how that filter behaves as its load varies.
