Hi.
I have a ETEC 4-port Wireless Modem Router. PT-3830. I don't want to use the modem just the router part as I no longer have an adsl connection but another network connection.
THis new network connection I connet to Port 1 on the back of the router and the green light is on for connectivity. I then plugged my laptop in Port 2 on the back of the router and my laptop had a green light for a good connection and I was able to get on the internet fine.
My problem is that the wireless side of things do not work. They used to work when I was using the ADSLmodem part of the router but the wirelink link will not behave in the same way as when I have the RJ45 Lan connections at the back of the router.
Q: Is it possible to configure the wireless part of my router to use the LAN connections rather than ADSL?
Thanks
Lee
