I would like to know how can you check if you are getting the right speed for your ADSL connection or not?
There are lot of websites that do the speed test for you and different websites show different results.
Is there a relation between the Transfer rate while downloading and the speed of the adsl connection. If yes then what should be the transfer rate for a 2Mbps connection.
How can once manually (not using speed tests on websites) find out the speed of the ADSL connection.
Any insight into this will be highly appreciated.
Regards,
~anthony
