Can I use Hyper terminal to communicate via the serial management cable to a Cisco 678 which is currently configured as a CAP modem with latest cbos 2.4.6?
Please tell if any or all of the following 3 possibilities will work:
A. Use hypertrminal and a serial conneciton to"set download code" using the transfer in function in hyperterminal.
B. using tftp, which seems more confusing, or
C. use the boot-up crtl-C to get in and do the routine I found on xmission general apparently from
df 10008000 --download the file to this location in memory --start and xmodem download with the 675 image --after transfer is complete you will see the # of bytes it --has written - e.g. 00fe8001 - you will need this later
pb 10008000 fee00000 --program the area of memory to flash area -- is the # of bytes (no brackets) the --monitor reported being downloaded
m0 --turn off monitor rb --reboot
