FAQ: Maximizing cable modem or DSL speed
Threaded View
Q: How do I get the maximum possible DSL or cable modem speed?
Should I use one of those tweaking programs?
A: See the Navas Cable Modem/DSL Tuning Guide at
<http://cable-dsl.navasgroup.com/ .
Re: FAQ: Maximizing cable modem or DSL speed
John Navas wrote:
Google "Cablenut"! It's a exe file that uses a given "ccs" file to
modify your registry. Than Google the "Shifter Custom.ccs file. These
files are available on two different sites.
Just run the program and use the Shifter Custom file. It will make 38
entries in your registry if you choose to use it. It also gives you the
option of backing up your registry if you choose. I recommend that you do.
It worked for me.
Good luck.
Site Timeline
