How do I make my Win95 OSR2 system to work with DSL or any other high speed connection? This is an old laptop with a Netgear PCMCIA network card. Model number FA411. I installed the driver and it seems to work properly. But Internet Explorer doesn't recognize the DSL connection. Do I need 3rd party software to make this work? If it is, where can I download the software? The software must be FREE and ISP INDEPENDENT.
Actually, I already have a router. I have another laptop with WinXP and it works perfectly. I just connect the cable to my ethernet card and WinXP automatically recognizes the connection. No need to type in user name, password or anything. But my older laptop doesn't recognize the connection.
Assuming your router is set with normal defaults for DHCP (auto IP assignment) for machines hooked up to it, then you need to be sure TCP/IP is installed as a component for the network card and TCP/IP is configured for DHCP. This page describes how to configure it for DHCP:
Once you have that or if you already have that all in place, then do a start>run>winipcfg and see if the router has given the card an IP. It normally will be in the 192.168.x.x range.
I understand Win95 supports only up to IE5.5. Download that if you don't have it and use the internet connection wizard that comes with it to configure a LAN connection.
IE5.5 can be downloaded here:
Consider an alternative browser, but you may have trouble finding a current version that is compatible with Win95. Perhaps other posters know of one. I don't believe the most current versions of Firefox or Mozilla will work in Win95. Opera might and is now free.
Most machines that can run Win95 can run Win98 - so consider upgrading to that (or better yet, installing it clean) so you can run more recent software.
Gary E
-- |Gary A. Edelstein | snipped-for-privacy@SPAMyahoo.com.invalid (remove NO SPAM and .invalid to reply) |"We have met the enemy and he is us." - Walt Kelly's Pogo
| How do I make my Win95 OSR2 system to work with DSL or any other high | speed connection? This is an old laptop with a Netgear PCMCIA network | card. Model number FA411. I installed the driver and it seems to work | properly. But Internet Explorer doesn't recognize the DSL connection. | Do I need 3rd party software to make this work? If it is, where can I | download the software? The software must be FREE and ISP INDEPENDENT. | | Hendra
You must be real cheap to try to connect Win95 to the Internet and then want FREE software !
Get a Cable/DSL Router such as the Linksys BEFSR41. Then the Router will make the PPPoE connection and will allow *any* TCP/IP compliant hardware to be connected to the LAN side of the Router.
| Actually, I already have a router. I have another laptop with WinXP and | it works perfectly. I just connect the cable to my ethernet card and | WinXP automatically recognizes the connection. No need to type in user | name, password or anything. But my older laptop doesn't recognize the | connection. | | Hendra
Just get your TCP/IP information from from the DHCP Daemon on the Router.
I also suggest you find the WINSOCK v2 and DUN 1.4 for Win95
DUN v1.4
I couldn't find the the 1999 patch for WINSOCK2 on MS Downloads. I have it though.
Hendra
On a side note, I haven't seen any security updates for Windows 95 since December of 2000. So do you really want to put that on the Internet? I still have one W95 machine that still runs my flatbed scanner. It won't work under W98, W2K, or XP. But I won't allow it on the network for security reasons.
Cheers!
______________________________________________ Bill (using a Toshiba 2595XDVD & Windows 98SE)
Here in comp.dcom.xdsl, "BillW50" spake unto us, saying:
I have several Win95 OSR2 boxes connected to the net, and with the use of a decent browser (e.g., Firefox) and a firewall (in my case, Coyote Linux 2.24 on a dedicated PC) it seems to be a fairly safe OS.
