I have an actiontec gt701 wireless gateway unit for my DSL. It gives me flawless service at nearly 6 Mb.
My problem comes when I want to use the phone on the same line (the DSL and voice are both from Qwest. I live in a very small town, so there are no good alternatives). I have two phone jacks in my house. One is in the living room where the Actiontec is plugged in. The other is in the bedroom.
The Actiontec has a jack to plug my phone into, and then it plugs into the phone jack on the living room wall. It came with a little filter to put between my second phone and the second jack. Here is what happens:
- When I leave the 2nd phone jack completely empty, I get perfect
- When I use the provided filter in the bedroom phone jack, I still get static and dropouts on my voice phone.
- By trying literally every possible combination, I found that the only way to get good voice phone quality is to use a 2-to-1 filter. It plugs into the 2nd phone jack, and accepts two input jacks --- one from my 2nd phone, and one from my old MSN DSL modem that I used for
The problem is that when I do this, my voice phone is perfect, but my DSL speed drops from 6Mb to 3.5 Mb (whether I'm on the phone or not). Note that the MSN modem is not plugged in to any PC or power source.
Can anyone suggest a way to get clear voice phone without cutting my DSL speed almost in half? Thank you.
