I'm quoting from Biju Sukumaran's DSL document:
"During the initialisation phase of the setting up of an ADSL connection, the capacity of each carrier of the DMT is evaluated and the maximum number of bits that can be stuffed into each carrier is determined. The bits to be transmitted are then distributed across these carriers, such that the carrier with the best performance gets the most bits and the most noisy one gets the least, or no bits. This means that the high performance carriers, which are usually the low frequency ones, are very finely modulated to a maximum of 15 bits. This is done in real time as well, so that the bit rate remains unaffected by the time varying nature of the noise in the channel."
My question now is, does the bit allocation of each frequency is determined only during initialization phase or does it change over time? In other words, after I have made the initial ADSL connection, does the bit allocations remain constant unless a resynchronization between ADSL modem and DSLAM is made?
Thanks, ennui
