I have 5 public, static ip addresses leased plus 3 more reserved. The range is:
63.x.x.n (reserved network) 63.x.x.n+1 (user assignable) 63.x.x.n+2 (user assignable) 63.x.x.n+3 (user assignable) 63.x.x.n+4 (user assignable) 63.x.x.n+5 (user assignable) 63.x.x.n+6 (reserved gateway) 63.x.x.n+7 (reserved broadcast)I have an internal network running on 192.168.0.x that has 2 webservers that the public internet needs to get to. When I had my Cisco 675, I simply enabled NAT and added NAT entries as follows:
set nat add entry 63.x.x.n+1 80 192.168.0.2 80 tcp set nat add entry 63.x.x.n+2 80 192.168.0.3 80 tcp
now any public HTTP traffic for 63.x.x.n+1 would go to my internal webserver @ 192.168.0.2 and HTTP traffic for 63.x.x.n+2 would go to
192.168.0.3.This procedure does not work on my Cisco 678. Will someone please let me know what I have to do in order to utilize my 5 public static IP addresses again? When I say "does not work" I mean the
Here is some diagnostic info off the 678:
cbos#sho nat
NAT is currently enabled
Port Network Global eth0 Inside wan0-0 Outside 63.x.x.n #reserved gateway IP vip0 Outside vip1 Outside vip2 Outside
Local IP : Port Global IP : Port Timer Flags Proto Interface
192.168.0.2:80 63.x.x.n+1:80 0 0x00041 tcp eth0 192.168.0.2:80 63.x.x.n+1:80 0 0x00041 udp eth0## where eth0 is Inside and using 192.168.0.1
cbos#sho int IP Address Mask eth0 192.168.0.1 255.255.255.240
vip0 0.0.0.0 255.255.255.248
vip1 0.0.0.0 255.255.255.0
vip2 0.0.0.0 255.255.255.0
wan0 Physical Port: Trained
Dest IP Address Mask wan0-0 207.x.x.x 255.255.255.255 # configured via IPCP
Any help would be greatly appreciated!
Thanks in advance,
-geoff.
