Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by jimiwonguk on January 26, 2006, 8:06 pm
Please log in for more thread options purchased netgear gd834g ADSL firewall router quite a while back but wondering if i can use it on a cable isp as im changing soon to a cable provider.... -- jimiwonguk | |||||||||||||||||||
Posted by William P.N. Smith on January 26, 2006, 10:32 pm
Please log in for more thread options Nope, DSL and cable are two different animals, with significantly different physical/electrical/signalling interfaces. What you _should_ do, IMHO, is rent the modem from the broadband provider(*) and buy a separate router. (*) Since you can't play with it, or tweak it, or even know if/how it's working, I consider it part of the infrastructure. | |||||||||||||||||||
Posted by jimiwonguk on January 27, 2006, 2:17 pm
William P.N. Smith Wrote: > jimiwonguk jimiwonguk.229r1b@broadbandbanter.com
> wondering if i can use it on a cable isp as im changing soon to a > cable > provider.... > > Nope, DSL and cable are two different animals, with significantly > different physical/electrical/signalling interfaces. > > What you _should_ do, IMHO, is rent the modem from the broadband > provider(*) and buy a separate router. > > (*) Since you can't play with it, or tweak it, or even know if/how > it's working, I consider it part of the > infrastructure. ic...but does it mean also that i cant network my pc and laptop wirelessly either, as i have a cable modem seperate from my cable isp. -- jimiwonguk | |||||||||||||||||||
Posted by William P.N. Smith on January 28, 2006, 12:58 am
>wirelessly either, as i have a cable modem seperate from my cable isp. You'll have to buy a separate WiFi router, which (unfortunately) is what you should have done originally. However, prices are pretty low, so it shouldn't be a big hardship. I like the Linksys WRT54G (preferably the V4 or GL version), but there are lots of WiFi Routers out there... | |||||||||||||||||||
| Similar Threads | Posted |
| can netgear gd834g work with cable isp? | January 26, 2006, 8:06 pm |
| Does the Netgear DG834G work reliably for anyone with PPPoE? | December 18, 2005, 10:15 am |
| I can't get my router to work | July 27, 2005, 2:08 am |
| Will DSL work with my phone system? | July 17, 2004, 3:28 pm |
| Getting PPoE to work on a Linksys | January 9, 2005, 1:06 pm |
| Speed Touch 330 now fails to work?? | September 13, 2005, 6:37 pm |
| Does the Actiontec GT701 work on a CAP circuit? | April 22, 2006, 7:43 pm |
| STOP what you’re doing - It doesn’t work! 5YWX | July 29, 2006, 1:34 pm |
| Australian-bought ADSL router. Will it work in Europe? | March 4, 2005, 3:09 am |
| Netgear DG632 & Aol | February 26, 2005, 5:19 pm |
| Netgear with SBC Yahoo DSL | November 7, 2005, 4:02 pm |
| Netgear DG632 Router & AOL | February 26, 2005, 5:09 pm |
| Actiontec + DSL + NEtgear VPN firewall | June 12, 2007, 9:31 am |
| Netgear DG834GT Demon ADSL | July 5, 2005, 7:54 pm |
| Netgear DG632 router can't get web pages | August 4, 2004, 9:40 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>provider....
