Bert,
Late last October, my 1.5/1.0 Qwest line (in the White Bear Lake area) was reprogrammed; my Cisco 678 was now training at 7168/896, and the SNR Margin dropped to 13dB, from it's usual 35-36dB. I would have been happy with the higher speeds, but I discovered my line just couldn't handle it, since the
678 kept retraining due to line quality. The occasional long lags when surfing was my tip-off that something wasn't right with my DSL service.My assumption (guess) is the higher speeds is now using the full frequency spectrum that DMT DSL runs at, and the SNR margin is an average of all the frequencies currently in use. As for the 9dB with the Actiontec, it may work fine with the 6M speed that it's training up at; where as my older Cisco had problems holding 7M with a slightly higher SNR. The DSL modems will negotiate download and upload speeds, based on line quality. Even though the central office is set to 7M/896K, your modem can only link up with the slightly slower speeds.
If stability becomes a problem, Qwest can drop your line down to 5M, and you will see an improvement in your SNR margin. Hopefully it won't come to that.
I've had a newsgroup message bookmarked which goes into detail on the difference between SNR from the older CAP and newer DMT technologies. If the link wraps badly, do a search for "Qwest DMT line quality question" in this newsgroup back from around 2001.
Hope this helps. Bob.
