Dear all,
AOL has a lot of troubleshooting help on this error but it all seems geared towards DSL *never* being connected. I have a different problem as the error only occurs the first time I try to connect from XP. But if I then cancel the error and try again a couple of mins later I can get into AOL OK. Once I've finally got into AOL I can come in and out of it all day.
On things is : if I start XP and wait a ridiculous amount of time (eg
10 mins) I can usually get in OK the first time - but it's not very practical of course.The standard things AOL has recommended to me include:
- reinstall BT Voyager drivers
- repair ACS files via control panel
- reinstall whole of AOL version 9.0
but they make no difference and are maybe not that relevant if I can get in eventually.
Could "Modem was unable to establish a DSL connection" come if there is some other process running or something in my Startup either missing or which shouldn't be there. For example, should AOLDIAL.exe be in the startup...?
I don't have any firewall installed at the moment, so that's not an issue.
I'd be very grateful for any ideas. thanks, Mark Stratford
