Does anyone have a valid schema for the Serial Cable for this device? (Its Rj45->DB9). For some reason I can't google the schema, and all my standard cables dont want to work with this device.
Thanks for any help.
| Hi, | | Does anyone have a valid schema for the Serial Cable for this device? (Its | Rj45->DB9). For some reason I can't google the schema, and all my standard | cables dont want to work with this device. | | Thanks for any help. | | -- | Mariusz Drozdziel
Schema ?
Do you mean a wiring diagram for a 9-pin Serial Port for this device ?
