Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Marco Terzuoli on February 10, 2005, 12:23 am
Please log in for more thread options I have 2 computers (a desktop and a laptop) and a wireless router. The desktop is connected to internet (through USB) and to the router (via ethernet). The laptop has a WiFi connection to the router. The IPs and operating systems are the following: desktop: 192.168.0.1 (Win2000) router: 192.168.0.2 laptop: 192.168.0.3 (WinXP) The netmask is 255.255.255.0. I can ping from one computer to another and from one computer to the router and can share folders between the two computers, but cannot access Internet with the laptop. I have already enabled on the desktop the option that allows the Internet connection to be shared. If I ping some srever (like www.google.com) from the laptop, I get an "unreachable destination host" error message. The router is an Asus WL-500g. Can anyone help me to configure this net? Thank you all very much, Marco | |||||||||||||||||||||||||
Posted by Some One on February 9, 2005, 8:04 pm
Please log in for more thread options First you need to disable internet connection sharing on all computers, the routher is taking care of sharing the internet connection, not the computers. What is your default gateway set to on each computer? It should be the address of the router. Go to the command prompt on the computers and type "ipconfig /all" (without the quotes), you should have at least one address in the DNS Servers line. | |||||||||||||||||||||||||
Posted by Ken Abrams on February 10, 2005, 2:43 am
> Hi,
> I have 2 computers (a desktop and a laptop) and a wireless router. The > desktop is connected to internet (through USB) and to the router (via > ethernet). The laptop has a WiFi connection to the router. The IPs and > operating systems are the following: <snip> If you stated the connections correctly, that is the problem; things are not connected properly. The intended (and most common) use of a router is for each computer to be connected to the router and then the ROUTER is connected to your ISP service (assuming you have DSL or Cable service). Basically, the cable from your Internet modem needs to connect to the router, not to your desktop machine. If your modem does not have an Ethernet port, then you are pretty much screwed. Assuming you have an instruction manual for the router, NOW would be a good time to actually read it! ;-) If you are trying to do this with a dial-up Internet connection, that is a whole different problem and (most of) the above answer does not apply. | |||||||||||||||||||||||||
Posted by Marilyn & Bob on February 10, 2005, 11:50 pm
>> Hi,
>> I have 2 computers (a desktop and a laptop) and a wireless router. The >> desktop is connected to internet (through USB) and to the router (via >> ethernet). The laptop has a WiFi connection to the router. The IPs and >> operating systems are the following: > <snip>
> > If you stated the connections correctly, that is the problem; things are > not > connected properly. > > The intended (and most common) use of a router is for each computer to be > connected to the router and then the ROUTER is connected to your ISP > service > (assuming you have DSL or Cable service). > > Basically, the cable from your Internet modem needs to connect to the > router, not to your desktop machine. If your modem does not have an > Ethernet port, then you are pretty much screwed. > Assuming you have an instruction manual for the router, NOW would be a > good > time to actually read it! ;-) > > If you are trying to do this with a dial-up Internet connection, that is a > whole different problem and (most of) the above answer does not apply. I think you have to read the OP's message again. From what I gather, he has a USB modem which cannot be connected directly to the router. Frankly, I don't think there is anything he can do with this setup unless the modem is a combined USB/ethernet modem like the Westell 2100 and 2200. In that case, he can follow your instructions, connecting the Modem to the Router via Ethernet cable and Router to Desktop via Ethernet cable and to laptop via wireless. If he does not have a dual cable type modem, the only practical solution is to replace the existing modem with an Ethernet capable one. -- Peace, BobJ | |||||||||||||||||||||||||
Posted by Ken Abrams on February 11, 2005, 1:09 am
> > router, not to your desktop machine. If your modem does not have an > > Ethernet port, then you are pretty much screwed. > I think you have to read the OP's message again.
Or maybe you should read my response a little closer? ;-) You DID do a better job of explaining the modem requirements than I did! Thanks. | |||||||||||||||||||||||||
about wireless router
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> router: 192.168.0.2
> Marco
