Digital Subscriber Line Zoom x6 DSL modem & multiple IP addresses (Verizon)
Subject Author Date
Zoom x6 DSL modem & multiple IP addresses (Verizon) Joel Kolstad 08-16-06
Posted by Joel Kolstad on August 16, 2006, 7:29 pm
Hello,
I currently having a working DSL setup with Verizon using a Zoom x6 modem.
The business this is for is changing their plan with Verizon such that, rather
than having a single dynamic IP address, we'll be getting 5 static IP
addresses.
Question: Will a Zoom x6 modem support multiple IP addresses? From reading
the manual and searching their knowledge base, I'm tending to think not. (On
the other hand, presumably the new modem Verizon supplies with their "self
install" kit will? I just rather like some of the x6's features and wanted to
keep it if possible.)
I've used various DSL & cables modems in the past, but never with more than
one (public) IP.
Thank you,
---Joel Kolstad
Posted by Joel Kolstad on August 16, 2006, 7:36 pm
I read a few other postings and figured I should provide more details about
the system:
-- At present, the Zoom x6 plays firewall & NAT. A switch is connected to the
Zoom's Ethernet port, which goes to the LAN... about 15 PCs, including a
server that has various ports directed across the Zoom for, e.g., incoming
e-mail, web access, etc. (This is a business class DSL connection -- this is
all on the up-and-up.)
-- Why multiple IPs? The company got a new office phone system from Vodavi.
It has a VoIP feature, so the 2nd IP is for the phone system's private use
(incoming VoIP sessions). Why not just route some ports from a single IP to
the phone system? Because -- and this is the answer from the local Vodavi
representative -- "Vodavi doesn't document what ports & protocols they use;
*all* ports must be available to the system." :-(
---Joel
Posted by Doug McIntyre on August 16, 2006, 7:54 pm
>addresses.
The Zoom x6 will do static IP routing just fine. From your subsequent
posting, you'll have to turn off NAT and the firewall though. So
you'll probably be adding another router behind this one. The Zoom
won't do concurrent NAT and static routing. Very few routers do.
Posted by Joel Kolstad on August 16, 2006, 11:28 pm
Thanks for the response, Doug. So I turn off the NAT & firewall options in
the X6 and -- poof -- it then just bridges the 5 static IPs over to the
Ethernet ports, eh? I'm thinking I'll then connect a Netgear FVS318 to do
the NAT/firewall and I guess just plug the phone system's VoIP port into the
X6 directly.
I did notice the X6 has a "half bridge" mode where it routes everything
to... a single MAC address, apparently? That doesn't sound like it would
help here.
If one is assigned multiple IP addresses and you leave NAT on, what happens?
It just picks up the first one of the block, perhaps?
---Joel
Posted by DLR on August 17, 2006, 12:42 am
> options in the X6 and -- poof -- it then just bridges the 5 static
> IPs over to the Ethernet ports, eh? I'm thinking I'll then connect a
> Netgear FVS318 to do the NAT/firewall and I guess just plug the phone
> system's VoIP port into the X6 directly.
> everything to... a single MAC address, apparently? That doesn't
> sound like it would help here.
"bridges" is a very misleading word here. I buy my business services
from a local ISP who offers the choice of routed or bridged. If I went
with Bellsouth it would be routed only. And routed gives you the 5 IPs.
With bridged you'd likely get a login for PPPoE which would assign YOUR
router an IP and route all 8 IPs of the block to your router.
> happens? It just picks up the first one of the block, perhaps?
Do you have control over the router?
For years I did the Static External IPs and 1 to many NAT and 1 to 1 NAT
with Netopia 9100s. They are a wee bit long in the tooth now. I'm
looking at Linksys RMxxxx units to replace them. (I want dual WAN
support). But you'll not find support for the 3 things at once and
multiple static IPs in the $50 after a rebate router.
If you have control over the router see if you can do all of the above.
Or at least Static IPs and many to 1 NAT at the same time. If not,
you'll need a router that you provide.
Similar ThreadsPosted
Zoom x6 DSL modem & multiple IP addresses (Verizon) August 16, 2006, 7:29 pm
DSL modem and router IP addresses February 15, 2008, 4:20 pm
Zoom Hayes H08-15810 vs Zoom X3 5560 December 10, 2004, 1:44 pm
Linsys with 5 static ip addresses. How to configure? September 21, 2005, 10:12 am
zoom X6 - does not detect dsl October 11, 2006, 12:09 pm
Zoom ADSL X5 connecting to Infinity Internet? November 16, 2005, 2:50 pm
PC not detecting Verizon DSL modem January 11, 2007, 2:34 pm
Verizon DSL - Password to Router/DSL modem? March 10, 2007, 6:53 pm
Multiple Static IP June 22, 2006, 1:22 am
Multiple broadband connection? September 28, 2005, 7:56 pm
Multiple broadband connection? October 3, 2005, 6:44 pm
multiple DSL lines for single infrastructure March 17, 2005, 12:19 am
Binding/Bonding multiple DSL connections? March 21, 2006, 12:47 pm
Multiple DSL Lines on single system September 20, 2006, 3:57 am
