Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by riggor9999 on March 28, 2009, 2:03 pm
First of all .... I apologize if this is off topic / or not the right group - but I am hoping that someone has the answer or can direct me to the answer. I just switched from Comcast to FIOS. vonage router as a router and it was connected to my phones. now I have verizon actiontec modem/router/wireless access point <--1--> vonage
the computers, printers, NAS storage, etc. Now basically - with Verizon
motorola vt2442 <-a-> phone lines, and <--2--> 16 port switch that has all FIOS, I have the 16 port switch connected to LAN port 1, and have the vonage motorola vt2442 connected to a LAN port 2, with only phones connected to the vonage motorola VT2442. All is working well - as I assumed it would. My question is ... are there any ports on the verizon actiontec router I need to open up to allow vonage to work correctly / better? I swept thru the vonage help site, dsl reports, vonage forums. There was only some reference to "IF you were having problems - open these ports". There was no discussion regarding voice QOS for vonage device/router behind another router. Also - no discussion regarding two way communication needed for vonage updates or heartbeat communications / firmware updates, etc. I called vonage tech support - and they knew less than the web site. They suggested putting the vonage motorola vt2442 in the dmz off the verizon actiontec router - but without any real rhyme or reason or explanation. Any info would be greatly appreciated. | ||||||||||
Posted by Bill M. on March 28, 2009, 2:38 pm
Please log in for more thread options snip >My question is ... are there any ports on the verizon actiontec router I
snip
>need to open up to allow vonage to work correctly / better? I've been using Vonage since 2005 and have never opened any ports for it on my router. -- Bill | ||||||||||
Posted by riggor9999 on March 28, 2009, 4:13 pm
> On Sat, 28 Mar 2009 14:03:52 -0400, "riggor9999"
> > snip >>My question is ... are there any ports on the verizon actiontec router I
>>need to open up to allow vonage to work correctly / better? > snip
> > I've been using Vonage since 2005 and have never opened any ports for > it on my router. > Thanks - and to confirm - you have it behind another router - correct? I have had Vonage since 2001 - but this the first time (not counting the original Motorola mta device they sent) that the vonage router is not prime. | ||||||||||
Posted by Bill M. on March 28, 2009, 6:31 pm
Please log in for more thread options On Sat, 28 Mar 2009 16:13:00 -0400, "riggor9999"
>> >> snip >>>My question is ... are there any ports on the verizon actiontec router I
>>>need to open up to allow vonage to work correctly / better? >> snip
>> >> I've been using Vonage since 2005 and have never opened any ports for >> it on my router. >> >
>Thanks - and to confirm - you have it behind another router - correct? > >I have had Vonage since 2001 - but this the first time (not counting the >original Motorola mta device they sent) that the vonage router is not prime. Yes, I have it behind a Linksys WRT54GL. -- Bill | ||||||||||
Posted by riggor9999 on March 28, 2009, 7:33 pm
>>> >>> snip >>>>My question is ... are there any ports on the verizon actiontec router I >>>>need to open up to allow vonage to work correctly / better? >>> snip >>> >>> I've been using Vonage since 2005 and have never opened any ports for >>> it on my router. >>> >>
>>Thanks - and to confirm - you have it behind another router - correct? >> >>I have had Vonage since 2001 - but this the first time (not counting the >>original Motorola mta device they sent) that the vonage router is not >>prime. >
> Yes, I have it behind a Linksys WRT54GL. > > -- > Bill Thanks. I have not had problems in the last 48 hours ... and I suspect the 20 mb down / 5 mb up ... will not put any undo load to affect QOS. | ||||||||||
| Similar Threads | Posted |
| Verizon FIOS and Vonage - QOS and ports question | March 28, 2009, 2:03 pm |
| Disabled ports on Verizon DSL? | December 20, 2004, 3:12 pm |
| All Inbound Ports Blocked on Verizon DSL? | May 28, 2005, 7:01 pm |
| Verizon dsl blocks all inbound ports | July 8, 2006, 11:49 am |
| FIOS | November 15, 2008, 5:58 pm |
| thinking of switching to Vonage | March 2, 2005, 10:37 am |
| Vonage and DSL on same phone line? | June 19, 2006, 6:35 pm |
| Verison FIOS, D-Link DI624, 2.43DDM firmware? | May 20, 2005, 2:41 pm |
| Stupid n00b DSL Verizon Question | December 12, 2004, 7:33 pm |
| Two routers and Openig Ports. | December 14, 2004, 10:59 pm |
| CAVTEL and incoming ports | June 1, 2006, 9:49 am |
| D-Link DSL-502T ethernet and USB ports at same time? | June 22, 2006, 8:41 pm |
| Non-DSL Question | July 14, 2005, 12:08 pm |
| Question About DMZ. Please Help. | October 23, 2005, 4:16 pm |
| Re: Question about DSL | April 12, 2007, 11:31 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
lines, and <-b-> 16 port switch that has all the computers, printers, NAS
