Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Gordo on August 26, 2004, 10:12 pm
Please log in for more thread options router, the setup works fine. I have been unsuccessful at adding a Linksys BEFW11S4 wireless router. Some specific questions: 1. Does the Westell setup have to change (e.g., to bridge mode) if a router is added downstream? 2. Both the modem and router have the same default IP address (192.168.1.1). When the router is added, that address points to the router setup page with no apparent conflict. Does the router IP address have to be changed (e.g., to 192.168.2.1)? It would be greatly appreciated if someone could summarize the setup process of adding the router. (I know what the hardware connections are.) Thanks for any suggestions. Gordo | ||||||||||||||||
Posted by Dick on August 26, 2004, 10:23 pm
Please log in for more thread options to a router. To add the wireless router, you need to turn the router function in the Westell off so that it is just a modem. Take a look at these two websites for help. http://support.easystreet.com/easydsl/equipment/westell/westell-setup.htm http://www.lava.net/support/config/dsl/westell/ Dick wrote: | ||||||||||||||||
Posted by John P. Dearing on August 27, 2004, 2:29 am
Please log in for more thread options Gordo wrote:
> I have a Windows Me PC with Verizon DSL and a Westell 2200 modem. Without a
> router, the setup works fine. I have been unsuccessful at adding a Linksys > BEFW11S4 wireless router. Some specific questions: > 1. Does the Westell setup have to change (e.g., to bridge mode) if a router > is added downstream? Yes, the Westell should be changed to bridge mode. You'll also need to configure the router to your area. This means to select PPPoE (mostly former Bell Atlantic areas) or DHCP (mostly former GTE areas). This configuration is done in the router since the router will now be doing the authentication on the VOL network (not the modem). > 2. Both the modem and router have the same default IP address (192.168.1.1).
> When the router is added, that address points to the router setup page with > no apparent conflict. Does the router IP address have to be changed (e.g., > to 192.168.2.1)? No, once you've reconfigured the Westell to bridge mode and setup the router, all will be fine. Just set your PC(s) to use DHCP (obtain address automatically) and it will be nearly plug and play from that point. Since the Windows ME PC is already obtaining an IP address from the Westell, any changes there will be quite minimal. You didn't mention installing WinPoet so I guess you're either former GTE and using DHCP on the WAN side or have the username/password programmed into the PPPoE shim on the Westell. Good luck! John -- John Dearing A+, Network+ | ||||||||||||||||
Posted by Sam on September 2, 2004, 3:30 pm
Please log in for more thread options Sometime on, or about Thu, 26 Aug 2004 23:29:49 GMT, John P. Dearing
>> router, the setup works fine. I have been unsuccessful at adding a Linksys >> BEFW11S4 wireless router. Some specific questions: >> 1. Does the Westell setup have to change (e.g., to bridge mode) if a router >> is added downstream? >
> Yes, the Westell should be changed to bridge mode. You'll also need to > configure the router to your area. This means to select PPPoE (mostly > former Bell Atlantic areas) or DHCP (mostly former GTE areas). This > configuration is done in the router since the router will now be doing > the authentication on the VOL network (not the modem). > >> 2. Both the modem and router have the same default IP address (192.168.1.1).
>> When the router is added, that address points to the router setup page with >> no apparent conflict. Does the router IP address have to be changed (e.g., >> to 192.168.2.1)? >
> No, once you've reconfigured the Westell to bridge mode and setup the > router, all will be fine. Just set your PC(s) to use DHCP (obtain > address automatically) and it will be nearly plug and play from that point. > > Since the Windows ME PC is already obtaining an IP address from the > Westell, any changes there will be quite minimal. You didn't mention > installing WinPoet so I guess you're either former GTE and using DHCP on > the WAN side or have the username/password programmed into the PPPoE > shim on the Westell. > > Good luck! > > John My Verizon connection, with a private ISP, uses a static IP address. Would I need to disable DHCP in the Westell 2200? I'm planning on installing a Linksys router with an 8-port switch [model BEFSR81] next week. I'm set up as Routed Bridge now... when I get the new router, besides just setting it to Bridged, would I need to turn off DHCP or anything else? Also, since the Linksys comes configured as 192.168.1.1, does this cause a conflict with the Westell? If so, how do I get around it? I find a lot of this sort of confusing. Sam -- To mail me, please get rid of the BS first | ||||||||||||||||
| Similar Threads | Posted |
| Verizon DSL with router | August 26, 2004, 10:12 pm |
| Verizon DSL - Password to Router/DSL modem? | March 10, 2007, 6:53 pm |
| Verizon DSL - SMTP Problems with Linksys Router | June 28, 2006, 3:16 pm |
| VERIZON DSL & NETGEAR MR8142 v2 Router & MA101 802.11b Wireless USB Adapter | March 9, 2005, 11:59 am |
| Semi-OT: Piggybacking a WiFi router onto existing FireWall router? | November 15, 2005, 9:58 am |
| ADSL Modem with a Built-in Router? Can I connect another router to it? | March 26, 2007, 2:41 am |
| How to connect a router to an ADSL router? | January 18, 2005, 6:02 pm |
| news.verizon.net | July 28, 2004, 12:27 pm |
| news.verizon.net | August 4, 2004, 5:19 am |
| trying to use Verizon DSL with linux | September 18, 2004, 2:26 pm |
| Some help with new Verizon DSL and existing AOL... | October 15, 2004, 2:24 pm |
| Verizon DSL password | November 4, 2004, 3:24 pm |
| Verizon Naked DSL? | February 27, 2005, 3:34 pm |
| Verizon DSL in MD problems | March 14, 2005, 7:41 am |
| Verizon Newsgroups | March 20, 2005, 12:49 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>to 192.168.2.1)?
>Gordo
