Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on September 9, 2006, 10:18 pm
I get a DSL download speed from ATT Yahoo DSL of about 320 kbps using a Speedstream 5260 modem with or without router....got the precise same speed from another router unsupported by ATT. I'm running XP on a Dell Latitude C600. I strongly suspect its a faulty DSL feed that's causing it. Any suggestions on what to try before I call ATT again? | ||||||||||||||||
Posted by GlowingBlueMist on September 10, 2006, 11:28 pm
Please log in for more thread options rfreeman77@gmail.com wrote: You might want to download a copy of TCP/IP Optimizer at http://www.speedguide.net/ and check to see if Windows tweaking might speed things up. Some ISP software installs programs that can confuse the settings and actually slow things down rather than speed things up like they claim. | ||||||||||||||||
Posted by GlowingBlueMist on September 11, 2006, 4:31 pm
GlowingBlueMist wrote: <snip>
Another problem that turns up time after time with new DSL installations is either bad quality internal wiring or unfiltered devices like alarm systems, answering machines, dial-in water or gas meters. Take your DSL modem and plug it directly into the telephone NIC jack (like you would a test phone) and either drag your computer there and try it or run a long Ethernet cable to the computer and see what speed you get. Stay away from wireless if possible while testing as it only adds another level of complexity where problems might exist. If your speed does go up to what you expected then the problem is something inside your home and not the Telco's or ISP's problem. | ||||||||||||||||
Posted by on September 11, 2006, 10:38 pm
It's an old line, probably capped....I've been getting lousy speeds for years but just never worried about it before. I'll try plugging in at the box as you suggest and report back. Thanks to all. GlowingBlueMist wrote: > GlowingBlueMist wrote:
> <snip> > > Another problem that turns up time after time with new DSL installations is > either bad quality internal wiring or unfiltered devices like alarm systems, > answering machines, dial-in water or gas meters. > > Take your DSL modem and plug it directly into the telephone NIC jack (like > you would a test phone) and either drag your computer there and try it or > run a long Ethernet cable to the computer and see what speed you get. Stay > away from wireless if possible while testing as it only adds another level > of complexity where problems might exist. If your speed does go up to what > you expected then the problem is something inside your home and not the > Telco's or ISP's problem. | ||||||||||||||||
Posted by Kay Archer on September 12, 2006, 4:34 pm
> years but just never worried about it before. I'll try plugging in at > the box as you suggest and report back. > We can hope they move your circuit to an RT. That would get you a shorter copper pair and (probably) improve your speed. | ||||||||||||||||
| Similar Threads | Posted |
| Slow ATT Yahoo DSL Speed with SS5260 | September 9, 2006, 10:18 pm |
| Linksys WRT54G SLOW | August 4, 2004, 5:25 am |
| Verizon DSL Connection Became Slow | October 21, 2004, 7:49 am |
| qwest dsl phx area so slow! | April 14, 2005, 6:04 pm |
| Slow Download / Fast Upload | February 2, 2005, 9:29 pm |
| DSL upload slow, starts off fast | April 1, 2005, 1:11 am |
| Odd Verizon behavior, fast, but slow | May 25, 2005, 6:30 pm |
| How to fix extremely slow 10Mbps DSL XPSP2 Bell Sympatico Connection | April 26, 2006, 6:25 pm |
| Fast Channel Vs. Slow Channel | December 12, 2004, 4:43 pm |
| SBC-Yahoo DSL equipments | December 13, 2004, 8:08 am |
| Question about new SBC/Yahoo DSL | July 29, 2005, 10:18 am |
| Yahoo Mail in DSL | September 13, 2005, 10:01 am |
| Netgear with SBC Yahoo DSL | November 7, 2005, 4:02 pm |
| SBC-Yahoo rate | January 4, 2007, 11:17 am |
| I *did* install the SBC Yahoo! DSL software, but on a Mac | July 25, 2004, 12:04 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
