Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Thomas Judge on December 7, 2005, 6:48 pm
Please log in for more thread options Hi, SBC yahoo DSL, Speedstream 5100, Dlink POS DI 614+. I recently flashed the firmware on the DLink in hopes of curing some wifi problems, doing so reverted to factory settings. Here's the odd thing - even though it is now set to Dynamic IP rather than PPPoE, it still works, even across powerdowns of both. Why is this? Is the speedstream caching the PPPoE info someplace? It's working so I dont want to break it but I have a feeling sooner or later it may stop.. Thanks Thomas | ||||||||||||||||||||||
Posted by Jeff Liebermann on December 7, 2005, 9:27 pm
Please log in for more thread options wrote: Yep. I ran into exactly the same thing last night. If you dive into the web config on your DI-614+, and check the "status" page, you'll find that the WAN IP's are 192.168.0.xxx which is coming from the Speedstream 5100. To fix the problem, disconnect the DI-614+ temporarily and plug the computer direction into the Speedstream 5100. Reboot or whatever until it connects again to the internet. Then, point your web browser to: http://192.168.0.1 You should get a menu that looks like: http://forums.ricknmiasworld.net/5100b/modeminfo.htm You can reset the modem to defaults on the "Reset" page. Then, go to the PPP Location page: http://forums.ricknmiasworld.net/5100b/ppplocation.htm and select "Bridged Mode". >It's working so I dont want to break it but I have a
>feeling sooner or later it may stop.. -- Jeff Liebermann jeffl@comix.santa-cruz.ca.us 150 Felker St #D http://www.LearnByDestroying.com Santa Cruz CA 95060 http://802.11junk.com Skype: JeffLiebermann AE6KS 831-336-2558 | ||||||||||||||||||||||
Posted by Marty on December 8, 2005, 11:26 am
Somewhere around Wed, 07 Dec 2005 21:27:43 -0800, while reading ba.internet, I think I thought I saw this post from Jeff Liebermann >Yep. I ran into exactly the same thing last night. If you dive into
I ran into that a while back and asked about it here, too. The person I was
>the web config on your DI-614+, and check the "status" page, you'll >find that the WAN IP's are 192.168.0.xxx which is coming from the >Speedstream 5100. > >To fix the problem, disconnect the DI-614+ temporarily and plug the >computer direction into the Speedstream 5100. Reboot or whatever >until it connects again to the internet. Then, point your web browser >to: > http://192.168.0.1 >You should get a menu that looks like: > http://forums.ricknmiasworld.net/5100b/modeminfo.htm >You can reset the modem to defaults on the "Reset" page. >Then, go to the PPP Location page: > http://forums.ricknmiasworld.net/5100b/ppplocation.htm >and select "Bridged Mode". > helping was having occasional problems that seemed to be related to the Linksys router. He could bypass the router and it would work. Then, I'd go over, reconnect the router, and it worked fine. So, I've never actually seen it fail. I suggested that next time, he recycle the power on the router, and that seems to work for him. I also replaced a cable from the router to the modem. So, I'm wondering now about "fixing the problem". Is the router better at PPPoe than the modem? Or is it just that it's easier to get to the router? -- Marty - public.forums (at) gmail (dot) com "Those are my principles, and if you don't like them... well, I have others." - Groucho Marx | ||||||||||||||||||||||
Posted by Jeff Liebermann on December 8, 2005, 12:31 pm
wrote: >Somewhere around Wed, 07 Dec 2005 21:27:43 -0800, while reading ba.internet,
>I think I thought I saw this post from Jeff Liebermann > >>Yep. I ran into exactly the same thing last night. If you dive into
>>the web config on your DI-614+, and check the "status" page, you'll >>find that the WAN IP's are 192.168.0.xxx which is coming from the >>Speedstream 5100. >> >>To fix the problem, disconnect the DI-614+ temporarily and plug the >>computer direction into the Speedstream 5100. Reboot or whatever >>until it connects again to the internet. Then, point your web browser >>to: >> http://192.168.0.1 >>You should get a menu that looks like: >> http://forums.ricknmiasworld.net/5100b/modeminfo.htm >>You can reset the modem to defaults on the "Reset" page. >>Then, go to the PPP Location page: >> http://forums.ricknmiasworld.net/5100b/ppplocation.htm >>and select "Bridged Mode". >> >I ran into that a while back and asked about it here, too. The person I was
>helping was having occasional problems that seemed to be related to the >Linksys router. He could bypass the router and it would work. Then, I'd go >over, reconnect the router, and it worked fine. So, I've never actually >seen it fail. I suggested that next time, he recycle the power on the >router, and that seems to work for him. I also replaced a cable from the >router to the modem. When I first started playing with the installation, I managed to dig out the one and only intermittent telco cable in my junk box. 30 minutes later, I figured out why the connection kept dropping. Argh. >So, I'm wondering now about "fixing the problem". Is the router better at
>PPPoe than the modem? Or is it just that it's easier to get to the router? I don't see any big difference between having the 5100b modem or the router do the PPPoE login. SBC's authentication servers will screw up regularly no matter which device is being used. However, when you enable PPPoE login in the modem, you also get NAT enabled at the same time. That means you can run without a router and connect multiple PC's to the modem. I never bothered to check if the 5100b turns off the DHCP server and disables NAT if I set the 5100b to the bridge mode. http://forums.ricknmiasworld.net/5100b/conncfg.htm It's one of the bottom settings. I did a grand reset followed by setting bridging mode. I didn't touch anything on the configuration page. Given the choice of running a real router versus whatever is inside the modem, I would take the real router. That's because I use port forwarding, port triggering, DDNS, SPI, IPSec VPN, QoS, and all the other wiz-bang features found in routers, but not in the Efficient 5100b modem. -- Jeff Liebermann jeffl@comix.santa-cruz.ca.us 150 Felker St #D http://www.LearnByDestroying.com Santa Cruz CA 95060 http://802.11junk.com Skype: JeffLiebermann AE6KS 831-336-2558 | ||||||||||||||||||||||
Posted by Kay Archer on December 8, 2005, 3:15 pm
> >I recently flashed the firmware on the DLink in hopes > >of curing some wifi problems, doing so reverted to > >factory settings. Here's the odd thing - even though > >it is now set to Dynamic IP rather than PPPoE, > >it still works, even across powerdowns of both. > >Why is this? Is the speedstream caching the PPPoE > >info someplace? >
> Yep. I ran into exactly the same thing last night. If you dive into > the web config on your DI-614+, and check the "status" page, you'll > find that the WAN IP's are 192.168.0.xxx which is coming from the > Speedstream 5100. > > To fix the problem, disconnect the DI-614+ temporarily and plug the > computer direction into the Speedstream 5100. Reboot or whatever > until it connects again to the internet. Then, point your web browser > to: > http://192.168.0.1 > You should get a menu that looks like: > http://forums.ricknmiasworld.net/5100b/modeminfo.htm > You can reset the modem to defaults on the "Reset" page. > Then, go to the PPP Location page: > http://forums.ricknmiasworld.net/5100b/ppplocation.htm > and select "Bridged Mode". > Is the Original Poster using a 5100 (4 lights) or a 5100b (5 lights)? I suspect the former. Which means that pppoe _must_ be on the router. If it is a 5100b, it would be a lot faster to reset the 5100b (reset switch is accessible from the bottom of the modem) and make sure the pppoe settings are correct in the router. My 4100 (nearly the same firmware as 5100b) has never been connected to a computer. | ||||||||||||||||||||||
| Similar Threads | Posted |
| SBC DSL..not PPPOE but dynamic IP? | December 7, 2005, 6:48 pm |
| SBC DSL..not PPPOE but dynamic IP? | December 7, 2005, 6:49 pm |
| SBC DSL..not PPPOE but dynamic IP? | December 7, 2005, 7:06 pm |
| SBC DSL..not PPPOE but dynamic IP? | December 7, 2005, 7:46 pm |
| Static or Dynamic IP? | July 13, 2004, 11:18 pm |
| Update of dynamic WAN IP | November 3, 2004, 8:51 am |
| Dynamic IP Address | December 17, 2004, 5:30 am |
| Changing static IP to dynamic | January 28, 2005, 12:55 am |
| Which ADSL provider's Dynamic IP changes the most often? | October 18, 2007, 2:33 am |
| accessing an ADSL dynamic IP from the internet? | August 24, 2004, 12:49 am |
| A pppoe question | January 21, 2007, 8:31 am |
| PPPoE and "allowable MTU" | January 1, 2005, 7:25 pm |
| DSL that also uses dial-up (PPPOE) | December 26, 2006, 6:01 pm |
| pppoe and L2TP question | October 28, 2004, 10:47 am |
| PPPoE software problem or... | November 11, 2004, 9:06 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>info someplace?
