Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Hans =?iso-8859-1?Q?J=F8rgen?= on April 3, 2008, 12:27 pm
Please log in for more thread options If your DSL vendor has a list of recomended modems follow that or you are on your own! Not all combinations chipset/firmware work equaly well. When my local telco do a full test they are testing at all cable lengths in 50meter(150feet) incriments. And they have found "funny" bugs. /hjj | ||||||||||||||||||||||
Posted by Who Me? on April 3, 2008, 6:48 pm
Please log in for more thread options > I guess that leaves me with the question of how the firmware can
> effect apparent line quality? It seems that line quality should be > independent of the chipset/firmware used. Can someone please explain > this? > If we forget for the moment that the term "line quality" is itself somewhat ambiguous........... The chipset/firmware may not be capable of making full use of a "good" line. Or there may be "glitches" in the good line. Or the equipment at your end might not be fully compatible with what the ISP has at his end. Or the equipment at your end might just be "bad". Not too complicated really. And to echo a previous post: If you insist on using equipment that is not on your ISPs approved list, then you're on your own.......and it doesn't sound like you are qualified to take up that challenge. | ||||||||||||||||||||||
Posted by Franc Zabkar on April 4, 2008, 7:31 pm
Please log in for more thread options On Wed, 2 Apr 2008 11:30:16 -0700 (PDT), Jon.R.Kibler@gmail.com put
finger to keyboard and composed: >Hi,
> >We have been having an on-going battle with several local telcos over >DSL line quality. For some reason their testers always show a much >higher line quality than does the routers. > >For example, I have taken the exact same DSL POTS cable, and plugged >it into a Cisco 827, 837, and 877 router and got essentially the same >line quality stats. When the local telco test the line (usually using >a SunSet MTT test set), they consistently see a good quality line, >where the routers see a marginal line -- one that keeps dropping. (And >this is not just a single line at a single location -- we have the >same problem at multiple locations, and at some locations, on multiple >lines at that location.) > >For example, here is what the router reports: > ATU-R (DS) ATU-C (US) >Capacity Used: 98% 53% >Noise Margin: 5.0 dB 12.0 dB >Output Power: 17.0 dBm 8.0 dBm >Attenuation: 64.0 dB 31.5 dB > Interleave Fast >Interleave Fast >Speed (kbps): 1216 0 >256 0 > >and the test set reports: > >Capacity: 47% / 40% >SNR: 8.5dB / 15dB >Attenuation: 40dB / 28dB >kbps: 1472 / 256 (noise profile) > >Why such a substantial disagreement between telco test sets and Cisco >routers? Especially when there is no difference between the wiring to >the device, up to and including the cable plugged into the device. > >This is getting to be a real pain. We have flaky connections and >numerous drops, yet the telco says everything is fantastic. It just >doesn't make sense. > >TIA for any insights into this problem. > >Jon K. Apart from the downstream attentuation, it seems that your two sets of readings are within agreement, there being a consistent 3.5dB difference which I suspect may reflect different refence points (?). The big 64dB versus 40dB discrepancy is a worry, though. Could there be a 24dB loss within your premises? (but wouldn't that affect the output power also???) FWIW, here is my ISP's explanation as to factors that may affect performance: http://www.internode.on.net/residential/internet/extreme/ There is also a "how fast can it be?" graph that charts speed versus attenuation. - Franc Zabkar -- Please remove one 'i' from my address when replying by email. | ||||||||||||||||||||||
Router vs. Telco DSL Quality Stats
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> this?
