Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by John Navas on June 18, 2007, 10:59 am
Please log in for more thread options On 6/18/07, Leewy wrote: What you want are switches with RFI filtering to prevent interference with DSL. > My question is, is there any RFI inteference filter that can be used
> to connect the phone line to the RFI Filter and from the RFI Filter > to the ADSL2 Modem? RFI filters are used to block interference on frequencies used by DSL, so they would also block the DSL signal itself. -- Best regards, John Navas <http:/navasgroup.com>
Posted by Rule-Ur-Wayz on June 18, 2007, 11:28 am
Please log in for more thread options > On 6/18/07, Leewy wrote:
> > I have read through your article on Navas Cable Modem/DSL Tuning
> > Guide, we have to replaced our dimmers switches that has the > > capability of filtering out RFI interference. >
> What you want are switches with RFI filtering to prevent interference > with DSL. > > > My question is, is there any RFI inteference filter that can be used
> > to connect the phone line to the RFI Filter and from the RFI Filter > > to the ADSL2 Modem? >
> RFI filters are used to block interference on frequencies used by DSL, > so they would also block the DSL signal itself. > > -- > Best regards, > John Navas <http:/navasgroup.com> Firstly, if the dsl dis-sync of the modem is caused by the dimmer switch, I would have to buy a new dimmer switch with RFI/EMI function for the modem to "adapt" to my dimmers? Secondly, my telephone wiring is more than 15 yrs now (2007) and I assume that it is now twisted/shielded PSTN/RJ11/CAT1 wires. Would that affect/cause interference to my ADSL2 modem? Would you recommend for a change? Thanks in advace | |||||||||||||
Posted by John Navas on June 18, 2007, 11:53 am
>> with DSL. >> RFI filters are used to block interference on frequencies used by DSL,
>> so they would also block the DSL signal itself. >Firstly, if the dsl dis-sync of the modem is caused by the dimmer
>switch, I would have to buy a new dimmer switch with RFI/EMI function Yes. >for the modem to "adapt" to my dimmers?
To prevent the switch from interfering with your DSL. >Secondly, my telephone wiring is more than 15 yrs now (2007) and I
>assume that it is now twisted/shielded PSTN/RJ11/CAT1 wires. Would It probably _is_ standard twisted-pair telephone wiring. >that affect/cause interference to my ADSL2 modem? Would you recommend
>for a change? What might help your DSL is to run a new dedicated high-grade cable (preferably CAT5) from a high-grade DSL splitter at the demarc <http://en.wikipedia.org/wiki/Demarc> to your DSL "modem". That avoids
any problems from your home phone wiring and eliminates the need for
micro-filters on all phone outlets (but not RFI filters on dimmers). -- Best regards, John Navas <http:/navasgroup.com>
Posted by Rule-Ur-Wayz on June 22, 2007, 1:37 am
Hi How about changing the ADSL2+ Modem to DLink or Linksys ADSL2+ Modems? I currently using Speedtouch 536v6 given by my ISP. Would it solve the DSL Problem without changing the dimmer switch? Next, I also realise that street lamps affect DSL Sync? I am staying at an high-rise apartment. Does street lamps affect DSL Sync no matter how high you live in an apartment? Leewy | |||||||||||||
| Similar Threads | Posted |
| Re: DSL problems caused by your own lighting (Dimmer Switches) | June 18, 2007, 10:59 am |
| SBC-DSL Problems | November 28, 2004, 3:06 pm |
| Several Problems | August 13, 2005, 1:47 am |
| FTP Problems with DSL | March 20, 2006, 8:31 am |
| dsl problems | July 17, 2006, 1:57 pm |
| Verizon DSL in MD problems | March 14, 2005, 7:41 am |
| ADSL Problems | February 20, 2006, 3:08 pm |
| Verizon DSL problems | May 12, 2006, 12:14 am |
| DSL and phone line problems HELP | September 7, 2004, 1:33 pm |
| VoOP over DSL problems and solutions? | February 14, 2005, 3:18 pm |
| DSL problems on some house jacks | April 6, 2005, 12:05 pm |
| Pipex and WAG54G Problems | June 1, 2005, 10:31 pm |
| DSL-300T configuration problems | October 15, 2005, 2:29 am |
| Problems with Verizon DSL and VPN connection | June 22, 2006, 4:24 pm |
| Help will be appreciated, problems with Verizon DSL | July 10, 2006, 2:42 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
