Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Brian Hill on February 6, 2006, 1:58 pm
Please log in for more thread options I have a Netopia 3386-ENT and 5 static IP addresses from my provider (which happens to be a terrestrial wireless service) . I would like to use all of the pubic IP addresses on the LAN side as well as some private 192.168 addresses (via DHCP) that would be NAT'd outbound to the router address. I would rather not NAT the public addresses to private addresses. This is the setup we have: Public Ranges: (yes, substitituing a 10 net for the real public one - last octet is real, however) 10.20.30.81/30 - small network between provider's wireless radio and my Netopia 10.20.40.16/29 - public address range of our static IP's Radio [10.20.30.81] <--> [10.20.30.82] Netopia [10.20.40.17] <--> hosts
[10.20.40.18-22]
I would like Radio [10.20.30.81] <--> [10.20.30.82] Netopia [10.20.40.17 &
(dhcp)]
192.168.0.1] <--> hosts [10.20.40.18-22 (static) and 192.168.X.X I don't think the passthrough option helps much, since that only works for one address. I don't see a way to have the Netopia have 2 addresses on the LAN side. Is this possible to do? Can this be done with VLANs, perhaps? If this should be reposted to another groups, please let me know. Thanks! Brian | |||||||||||||
Posted by DLR on February 6, 2006, 2:21 pm
Please log in for more thread options Brian Hill wrote: > I have a Netopia 3386-ENT and 5 static IP addresses from my provider
If it works like the R9xxx routers I can help you.
> (which happens to be a terrestrial wireless service) . I would like to > use all of the pubic IP addresses on the LAN side as well as some > private 192.168 addresses (via DHCP) that would be NAT'd outbound to > the router address. I would rather not NAT the public addresses to > private addresses. This is the setup we have: > > Public Ranges: (yes, substitituing a 10 net for the real public one - > last octet is real, however) > > 10.20.30.81/30 - small network between provider's wireless radio and my > Netopia > 10.20.40.16/29 - public address range of our static IP's > > Radio [10.20.30.81] <--> [10.20.30.82] Netopia [10.20.40.17] <--> hosts > [10.20.40.18-22] > > I would like > > Radio [10.20.30.81] <--> [10.20.30.82] Netopia [10.20.40.17 & > 192.168.0.1] <--> hosts [10.20.40.18-22 (static) and 192.168.X.X > (dhcp)] > > I don't think the passthrough option helps much, since that only works > for one address. > > I don't see a way to have the Netopia have 2 addresses on the LAN side. > > Is this possible to do? > > Can this be done with VLANs, perhaps? > > If this should be reposted to another groups, please let me know. > > Thanks! > > Brian > Do they want you to have your router's WAN address 10.20.30.82? | |||||||||||||
Posted by Brian Hill on February 6, 2006, 7:06 pm
Hello DLR, I am not sure, but I suspect so. The Linksys we had before was set up this way. The Radio may be set up to specifically route traffic destined for the 10.20.40.17 subnet to 10.20.30.82. I am not sure that the R9xxx routers and the 3000 series routers are similar enough to 'yes' to your question, but they might be. What are you suggesting? Brian | |||||||||||||
Posted by DLR on February 7, 2006, 4:05 pm
I don't know the if the menus match the R9100 or not and how much you know.
> (which happens to be a terrestrial wireless service) . I would like to > use all of the pubic IP addresses on the LAN side as well as some > private 192.168 addresses (via DHCP) that would be NAT'd outbound to > the router address. I would rather not NAT the public addresses to > private addresses. This is the setup we have: > > Public Ranges: (yes, substitituing a 10 net for the real public one - > last octet is real, however) > > 10.20.30.81/30 - small network between provider's wireless radio and my > Netopia > 10.20.40.16/29 - public address range of our static IP's > > Radio [10.20.30.81] <--> [10.20.30.82] Netopia [10.20.40.17] <--> hosts > [10.20.40.18-22] > > I would like > > Radio [10.20.30.81] <--> [10.20.30.82] Netopia [10.20.40.17 & > 192.168.0.1] <--> hosts [10.20.40.18-22 (static) and 192.168.X.X > (dhcp)] > > I don't think the passthrough option helps much, since that only works > for one address. > > I don't see a way to have the Netopia have 2 addresses on the LAN side. > > Is this possible to do? > The brief answer is to set up the router with a WAN address of 10.20.30.82 and to have it do 1 to many NAT. Once this is working go the IP Setup choice on the Quick menus and add a subnet for 10.20.40.16/29 Any devices you want to have on this subnet will want to use .16 as your their gateway/router address which will be the Netopia. You'll also need to set up a map of the external IPs to the internal one in the NAT screen. First define the internal and external ranges, then enter them in the Map list. | |||||||||||||
| Similar Threads | Posted |
| Netopia 3386-ENT using public and private IP ranges | February 6, 2006, 1:46 pm |
| Netopia 3386-ENT using public and private IP ranges | February 6, 2006, 1:58 pm |
| DSL wireless ranges | July 19, 2004, 1:29 pm |
| Public access with WinPoET | November 23, 2005, 10:36 am |
| Re: How do you set a public ip address on a 2wire router?? | May 3, 2007, 5:20 pm |
| Cisco 678 -- How do I configure it to use my 5 public, static IP's? | October 2, 2004, 4:23 pm |
| How can I access my Router which is on private ip address from ISP | October 29, 2005, 9:09 am |
| Netopia 3347W-ENT NTP | August 18, 2005, 2:01 pm |
| Netopia 5300-T Routers | January 4, 2005, 9:29 am |
| FA: Netopia DSL Modem (#3341) | March 9, 2005, 1:13 am |
| Netopia R9100 Configuration help?? | March 28, 2005, 1:27 pm |
| Netopia, DHCP Relay and VPN | December 9, 2005, 11:48 am |
| WTB Netopia 3300 Series | November 16, 2006, 9:14 am |
| Earthlink Netopia 3341 UHP config | July 20, 2005, 1:48 am |
| Netopia R9100 Static IP Setup | January 14, 2006, 9:35 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
