Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on August 15, 2006, 8:17 pm
Please log in for more thread options Hi, I did some searches and there are lots of people having connection issues but I couldn't find exactly what I'm experiencing. We have a (Dell) notebook with a AirLink+ USB wireless device and a no-name desktop with an AirLink wireless card. They both connect to a Linksys router which is now connected to an SBC/Yahoo DSL modem. We switched about a week ago from another DSL provider where things were working fine then (but the costs were much higher). The desktop has only been used the last few days and it seems ok. But for the last week, I've been trying to use the notebook but it seems to lose internet connectivity every few minutes. At first, I was doing an ipconfig /release and /renew which worked most of the time (but it seems to be dropping down to only half the time). Then I noticed that I could always get to my router and if I used their utilities to do a traceroute to something like Yahoo, that would pretty much always work and then everything else would (usually) start working again after that (ping would sometimes work in this situation but never from the cmd line, only occassionally from the router utilities page). I'm not sure how to fix this. We're both running XP, using wireless, to the same router but the notebook keeps losing the connection. One difference is that I installed the SBC/Yahoo programs from their CD on the notebook and then disabled them from 'net access using ZoneAlarm when I found out they send info to SBC. The one time I let them run, it didn't seem to drop the connection (but it also doesn't (usually) drop it as long as I'm actively using it without breaks). I'll likely just uninstall those at some point. So is this related to firewall settings, dhcp, dynamic IPs, MTU, something else? I have line filters everywhere and I've scanned my machine for malware multiple times (with several programs) in the last week. Thanks for any suggestions! | ||||||||||||||||
Posted by John Navas on August 15, 2006, 8:30 pm
Please log in for more thread options On 15 Aug 2006 17:17:16 -0700, sdaws06@gmail.com wrote in What are the _exact_ symptoms? Does the wireless icon in the system tray show a red X? Or this just a browser problem? Can you ping the wireless router? >At first, I was doing an
>ipconfig /release and /renew which worked most of the time (but it >seems to be dropping down to only half the time). The next time it happens, Run: %COMSPEC% /K IPCONFIG /ALL and post the results here. >Then I noticed that
>I could always get to my router and if I used their utilities to do a >traceroute to something like Yahoo, that would pretty much always work Pretty much? >and then everything else would (usually) start working again after that
>(ping would sometimes work in this situation but never from the cmd >line, only occassionally from the router utilities page). What happened _exactly_ from the command line? >I'm not sure how to fix this. We're both running XP, using wireless,
>to the same router but the notebook keeps losing the connection. One >difference is that I installed the SBC/Yahoo programs from their CD on >the notebook and then disabled them from 'net access using ZoneAlarm >when I found out they send info to SBC. The one time I let them run, >it didn't seem to drop the connection (but it also doesn't (usually) >drop it as long as I'm actively using it without breaks). I'll likely >just uninstall those at some point. With a wireless router you don't need the SBC/Yahoo software -- get rid of it. >So is this related to firewall settings, dhcp, dynamic IPs, MTU,
>something else? I have line filters everywhere and I've scanned my >machine for malware multiple times (with several programs) in the last >week. Hard to say without a lot more information. -- Best regards, FAQ for Wireless Internet: <http://Wireless.wikia.com>
John Navas FAQ for Wi-Fi: <http://wireless.wikia.com/wiki/Wi-Fi> Wi-Fi How To: <http://wireless.wikia.com/wiki/Wi-Fi_HowTo> Fixes to Wi-Fi Problems: <http://wireless.wikia.com/wiki/Wi-Fi_Fixes> | ||||||||||||||||
Posted by on August 16, 2006, 12:24 am
Hi John, Thanks for your reply. John Navas wrote: > What are the _exact_ symptoms? Does the wireless icon in the system
> tray show a red X? Or this just a browser problem? Can you ping the > wireless router? I have 2 icons: the WLan Utility for the wireless device and the network connection icon. I've had the X before but in these cases, both seem to show that I'm connected (but sometimes the little animation for each one isn't going). During this time, I can't ping any sites from the command line (ping just sits there for a long time and then gives an error - maybe a lookup issue?). I *can* ping the router from the command line. And I can get to it from the browser (but no other sites). If I do ipconfig /release and /renew or if I use the router traceroute utility (from the browser), things usually start working again. > The next time it happens, Run:
> %COMSPEC% /K IPCONFIG /ALL > and post the results here. Windows IP Configuration Host Name . . . . . . . . . . . . : <my computer name>
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Ethernet adapter Local Area Connection: Media State . . . . . . . . . . . : Media disconnected <it usually says this>
Description . . . . . . . . . . . : 3Com 3C920 Integrated Fast
Ethernet Controller (3C905C-TX Compatible) Physical Address. . . . . . . . . : <my builtin ethernet card mac addr>
Ethernet adapter Wireless Network Connection 2: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : IEEE 802.11g USB Wireless LAN #3 Physical Address. . . . . . . . . : <my usb device mac addr>
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 192.168.1.100 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DNS Servers . . . . . . . . . . . : 192.168.0.1 Lease Obtained. . . . . . . . . . : Tuesday, August 15, 2006 20:37:59 Lease Expires . . . . . . . . . . : Wednesday, August 16, 2006 20:37:59 > >Then I noticed that
> >I could always get to my router and if I used their utilities to do a > >traceroute to something like Yahoo, that would pretty much always work >
> Pretty much? Usually it would work, sometimes (rarely) it wouldn't. > What happened _exactly_ from the command line?
c:\>ping yahoo.com
Ping request could not find host yahoo.com. Please check the name and
try again. C:\>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data: Reply from 192.168.1.1: bytes=32 time=2ms TTL=64 Reply from 192.168.1.1: bytes=32 time=2ms TTL=64 ... Browser can access router but nothing else. After /release /renew (or router traceroute), everything works again for a few minutes (cmd line ping, browser, etc). > With a wireless router you don't need the SBC/Yahoo software -- get rid
> of it. Ok. | ||||||||||||||||
Posted by John Navas on August 16, 2006, 12:42 am
>> tray show a red X? Or this just a browser problem? Can you ping the >> wireless router? >
>I have 2 icons: the WLan Utility for the wireless device and the >network connection icon. I've had the X before but in these cases, >both seem to show that I'm connected (but sometimes the little >animation for each one isn't going). During this time, I can't ping >any sites from the command line (ping just sits there for a long time >and then gives an error - maybe a lookup issue?). What _exact_ error? Guesswork makes it much harder to help. >I *can* ping the
>router from the command line. And I can get to it from the browser >(but no other sites). Good. Then you have wireless connectivity, and the router is probably working. Thus the likely problem is Internet connectivity. Does the router have a status page that shows WAN/Internet status? If so, what _exactly_ does it say when this problem occurs? >If I do ipconfig /release and /renew or if I use
>the router traceroute utility (from the browser), things usually start >working again. How about when you sacrifice small animals? >Ethernet adapter Wireless Network Connection 2:
> > Connection-specific DNS Suffix . : > Description . . . . . . . . . . . : IEEE 802.11g USB Wireless LAN #3 > Physical Address. . . . . . . . . : <my usb device mac addr> Why would you withhold the MAC address? > Dhcp Enabled. . . . . . . . . . . : Yes
> Autoconfiguration Enabled . . . . : Yes > IP Address. . . . . . . . . . . . : 192.168.1.100 > Subnet Mask . . . . . . . . . . . : 255.255.255.0 > Default Gateway . . . . . . . . . : 192.168.1.1 > DHCP Server . . . . . . . . . . . : 192.168.1.1 > DNS Servers . . . . . . . . . . . : 192.168.0.1 That's a proxy in the router. > Lease Obtained. . . . . . . . . . : Tuesday, August 15, 2006 20:37:59
> Lease Expires . . . . . . . . . . : Wednesday, August 16, 2006 20:37:59 So DHCP is working and the computer is properly configured. Thus Release and Renew aren't called for. >> What happened _exactly_ from the command line?
>c:\>ping yahoo.com
>try again. Then DNS is failing. The router may have lost Internet connectivity. Focus on finding out if the router is losing Internet connectivity and why. Start by checking the router status screen, and checking the lights on the DSL modem. The next time you have a problem, try just restarting the DSL modem. -- Best regards, FAQ for Wireless Internet: <http://Wireless.wikia.com>
Posted by on August 16, 2006, 1:00 am
John Navas wrote: > What _exact_ error? Guesswork makes it much harder to help.
Sorry - I did include it below. There really isn't any specific error that points to the problem - otherwise I'd use that to search for a solution. > Good. Then you have wireless connectivity, and the router is probably
> working. Thus the likely problem is Internet connectivity. Does the > router have a status page that shows WAN/Internet status? If so, what > _exactly_ does it say when this problem occurs? It does have a few status pages (Router, Local Network, Wireless). >From what I recall when I last checked these when things weren't
working, everything looked alright (I'll check again when the problem
recurs). > How about when you sacrifice small animals?
I only have one so I haven't tried that yet. > Why would you withhold the MAC address?
For fun? > That's a proxy in the router.
ok...... > So DHCP is working and the computer is properly configured. Thus
> Release and Renew aren't called for. Except that things *aren't* working unless I do that. It _looks_ like everything is fine when the problem happens but I can't get to any sites past the router (including sbc) until I get the router to do something that seems to reset things. > Then DNS is failing. The router may have lost Internet connectivity.
Ok, but why/how? And how come the other computer works (I can have this issue several times at the same time the other one is working fine - very strange). > Focus on finding out if the router is losing Internet connectivity and
> why. Start by checking the router status screen, and checking the > lights on the DSL modem. The next time you have a problem, try just > restarting the DSL modem. Ok. Thanks. | ||||||||||||||||
| Similar Threads | Posted |
| Continually losing SBC Yahoo! DSL connection - can you help? | January 17, 2005, 2:39 pm |
| Losing connection (Computer->Wireless->Router->DSLmodem) | August 15, 2006, 8:17 pm |
| modem losing sync | August 19, 2005, 7:38 pm |
| DSL connection | August 15, 2004, 12:35 pm |
| Internet Connection | July 16, 2004, 1:09 pm |
| Internet Connection | August 9, 2004, 12:24 pm |
| USB to Ethernet connection? | July 25, 2005, 8:14 pm |
| DSL connection problem | December 15, 2005, 10:57 am |
| Why is my connection breaking!?! | July 16, 2005, 10:05 pm |
| Verizon DSL Connection Became Slow | October 21, 2004, 7:49 am |
| Problem with network connection | November 9, 2004, 7:53 pm |
| SBC DSL Connection Problem and Solution | August 22, 2005, 8:23 pm |
| Multiple broadband connection? | September 28, 2005, 7:56 pm |
| Multiple broadband connection? | October 3, 2005, 6:44 pm |
| Problems with Verizon DSL and VPN connection | June 22, 2006, 4:24 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
