Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on November 13, 2005, 10:40 pm
Please log in for more thread options How do you use those /29 sticky (static) IPs from SBC and be protected? Our office LAN 192.168.0.x network is simple. Only two PCs (one of which is wireless getting IP from our linksys router), one networked printer, and two network cameras (SONY SNC-M3). I need the two cameras and the main PC to be mapped to three public IPs so that the management from HQ can come in to browse the cameras and map Drive D on main PC. I have subscribed SBC static DSL with speed of 1.5m to 3m. SBC gave me a /29 subnet of 6 useable sticky IPs which I need to do a PPPoE authenication. When I do the PPPoE on the WAN side, I have one IP (67.64.xx.118) assigned to the WAN interface. How can I use the rest of the 5 IPs? The linksys wireless router doesn't map the LAN side IPs to the WAN side IPs (for example 192.168.0.117 to 64.xx.117, and 192.168.0.116 to 67.64.xx.116) so as to allow outsiders to come thru the router to see the network cameras. Even if the linksys did do it, I still need to restrict only outsiders (the HQ mgmt) to come in, not anyone else. Linksys WRT54G is simply not a firewall. So, two days ago, I installed a PIX-506 cisco firewall and moved the linksys behind it. I found out the PIX506 does do PPPoE and was able to get the IP but it still doesn't do the LAN IPs to WAN IPs mapping. I gave up and put the linksys back. Then I found out the article: http://www.dslreports.com/faq/3759. I am still researching to find a DSL router that has the DSL modem built-in, wireless 802.11G, stateful inspection firewall, and maps LAN IPs to WAN IPs. I looked at Netopia 3347W but found out that when the address mapping is enable, the so-called stateful inspection is not possible. If you have comment/solution, please suggest. | |||||||||||||
Posted by David Schwartz on November 14, 2005, 10:06 pm
Please log in for more thread options I have yet to see a commodity DSL router that would allow you to use both static IPs and NAT at the same time. Your best choice is probably to get a router that can run a Linux distro and configure that to do whatever you need. I recommend openwrt, but they're all good. DS | |||||||||||||
| Similar Threads | Posted |
| How do you use those /29 sticky (static) IPs from SBC and be protected? | November 13, 2005, 10:40 pm |
| sticky ip = static ip? | April 14, 2005, 4:10 am |
| Static or Dynamic IP? | July 13, 2004, 11:18 pm |
| Multiple Static IP | June 22, 2006, 1:22 am |
| Changing static IP to dynamic | January 28, 2005, 12:55 am |
| Changing locations for static DSL | April 4, 2005, 4:15 am |
| static + dhcp mix problem | December 27, 2006, 1:15 pm |
| Linksys BEFSR 41 - static ip? | May 10, 2007, 8:14 am |
| Static IP on residential line | October 9, 2007, 11:15 pm |
| Linsys with 5 static ip addresses. How to configure? | September 21, 2005, 10:12 am |
| Fast Access and Bellsouth DSL static-ip | October 17, 2005, 10:36 am |
| Fast Access and Bellsouth DSL static-ip | October 17, 2005, 10:37 am |
| Fast Access and Bellsouth DSL static-ip again | October 17, 2005, 10:37 am |
| Netopia R9100 Static IP Setup | January 14, 2006, 9:35 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
