Digital Subscriber Line Help me get my ZyXEL Prestige 643 reset, please!
Subject Author Date
Help me get my ZyXEL Prestige 643 reset, please! grummanf6f 06-04-06
Posted by on June 4, 2006, 2:54 pm
Okay, so this is what happened.
My big bro, the tech wiz (har har har) graciously donated the
aforementioned adsl device to me, the needy kid brother.
Unfortunately the strings attached said that he had no idea of the user
name or password he had set for the device. So, I searched the web and
found a site that told me to
1) unplug phone line
2) plug in RJ45
3) turn modem on
4) within 3 minutes of the SYS light coming on, go to browser and enter
http://192.168.1.1
5) enter admin as user and the device Ethernet address (conveniently
located below the device) as the password.
Alas, no can do. The thing bounces back to the login screen. Apparently
my bro (or whoever set it up for him, setting up a lightbulb is a
challenge to him) changed all the passwords available.
My question therefore is, can one nuke / set fire to / manipulate the
innards of the modem so that it somehow would forget its grim past life
in the service of my brother and return to this benign world?
As I understand it, if I had a serial cable to the device I could fire
it up and it would pop up a terminal screen where a simple 1234 would
suffice as a password? But this is dreaming, since all passwords have
been fiddled with.
Thank you oh gurus / guru-ettes!
Posted by Peter on June 4, 2006, 6:05 pm
Greetings,
> been fiddled with.
I know nothing about the ZyXEL sorry, but if a serial connection is
required, then that requires YOUR physical presence at the device
(whereas access via an IP addres does not), so there may be an
unalterable manufacturer password that can be used to gain access. Its
certainly wrth trying, all you need is the right serial cable.
Good luck...
Peter from Auckland.
Posted by mrbubl on June 4, 2006, 6:38 pm
Peter wrote:
> Greetings,
>> been fiddled with.
> Good luck...
http://www.zyxel.com/web/product_family_detail.php?PC1indexflag=20040812093058&CategoryGroupNo=7A36F2D9-B3EC-400A-86D9-7B4D9241F3BC
Posted by mrbubl on June 4, 2006, 6:39 pm
Peter wrote:
> Greetings,
>> been fiddled with.
> Good luck...
http://www.covad.com/onlinesupportcenter/setup/beginner/internet/telesoho/docs/TeleSoho_Password_Reset.pdf
Posted by on June 5, 2006, 4:25 am
mrbubl kirjoitti:
Thanks for this, I actually stumbled on this myself, and tried it,. I
can see the login screen and can enter 'admin' and the device Ethernet
ID, but it does not proceed inside the admin application.
Any other ideas? ZyXEL FInland suggested that if warranty has not
expired, I send them the device, but it is at least 3 years old, so no
luck.
Similar ThreadsPosted
Help me get my ZyXEL Prestige 643 reset, please! June 4, 2006, 2:54 pm
zyxel January 18, 2006, 1:38 pm
How To Reset A Westell Modem To Factory Defaults? March 1, 2005, 12:20 am
Zyxel PPPoA Bridging to Dreytek 2910 February 18, 2008, 4:54 pm
Using ADSL connection with ZyXEL P645R-A1 and D-Link DI714P+ October 3, 2004, 6:24 pm
