Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by John Navas on March 23, 2009, 10:56 am
Should I use one of those tweaking programs? A: See the Navas Cable Modem/DSL Tuning Guide at <http://cable-dsl.navasgroup.com/>.
Posted by Theslaz on March 23, 2009, 12:01 pm
Please log in for more thread options > Q: How do I get the maximum possible DSL or cable modem speed?
Google "Cablenut"! It's a exe file that uses a given "ccs" file to
> Should I use one of those tweaking programs? > > A: See the Navas Cable Modem/DSL Tuning Guide at > <http://cable-dsl.navasgroup.com/>. modify your registry. Than Google the "Shifter Custom.ccs file. These files are available on two different sites. Just run the program and use the Shifter Custom file. It will make 38 entries in your registry if you choose to use it. It also gives you the option of backing up your registry if you choose. I recommend that you do. It worked for me. Good luck. | ||||||||||
FAQ: Maximizing cable modem or DSL speed
Yahoo!
Windows Live
del.icio.us
digg
Netscape
