Digital Subscriber Line DSL connection
Subject Author Date
DSL connection Daniel Tan 08-15-04
---> Re: DSL connection David Efflandt08-16-04
Posted by Daniel Tan on August 15, 2004, 12:35 pm
Sometimes my DSL connection will disconnected, the DSL light on my
modem will keep on blinking. I'm using PPPoE. Is that affected by the
software or IPS connection ? Thanks
Rgds
Daniel
Posted by David Efflandt on August 16, 2004, 4:41 am
You do not say what hardware (modem or modem/router) and software. But
typically when the DSL LED on modem is blinking, you have lost sync, and
PPPoE is not going to work until the it gets a steady DSL LED. If you
have ethernet or act lights, it is normal for those to blink when there is
network traffic.
Could be any number of reasons, weak signal, bad outside or inside
wiring or jack, bad or missing filter on some other phone equipment. Not
sure what you have in your part of the world, but here we typically have a
box outside called a NID that marks the point where the telephone company
wiring ends and our own wiring begins. The home wiring plugs into a
modular (RJ11 jack), so we can just disconnect the home wiring, and plug
the modem right into the NID to rule out any inside wiring problems. If
we still have a problem there it is a telephone company problem.
David Efflandt - All spam ignored http://www.de-srv.com/
Posted by Daniel Tan on August 16, 2004, 10:34 am
Hi, i have DSL modem. My DSL wiring just plugged into the RJ11 phone
jack and everythings seems normal outside. But from what u mentioned,
the diconnection is most likely caused by hardware ?
Rgds
Daniel
efflandt@xnet.com (David Efflandt) wrote in message
> network traffic.
Posted by David Efflandt on August 17, 2004, 1:13 am
If you using individual filters for each phone device, make sure that all
devices connected to phone system (except the DSL modem) have DSL filters.
For example phones, dialup/fax modems or fax machines, answering machine,
and in my case filtering my water meter read by phone.
But it could be a problem with wiring between you and telco or at the
telco. I once had trouble making long distant calls and it turned out
there was a bad connection at the phone company between local and long
distance carrier. They had to reseat a connector or card at their end.
>> network traffic.
http://www.autox.chicago.il.us/ http://www.berniesfloral.net/
Posted by NormanM on August 16, 2004, 1:05 pm
says...
Heh. I only just got one of those a couple of weeks ago. The tech who
installed it seemed to think that it should have been done when we got the
DSL service 3-1/2 years ago. But everything worked, until three weeks ago,
or so. Oh, the tech didn't think that changing the NID would fix the
problem; he did it to make it easier to isolate the premises wiring and
connect a phone directly to the network. The old carbon block NID would
require an alligator clip fixture to connect a POTS device to the network,
after disconnecting the premises.
Oh, the short of it was that they had to switch us to another pair. None of
the CPE was at fault; something down the wire.
Norman
~Win dain a lotica, En vai tu ri, Si lo ta
~Fin dein a loluca, En dragu a sei lain
~Vi fa-ru les shutai am, En riga-lint
Similar ThreadsPosted
DSL connection August 15, 2004, 12:35 pm
Internet Connection July 16, 2004, 1:09 pm
Internet Connection August 9, 2004, 12:24 pm
USB to Ethernet connection? July 25, 2005, 8:14 pm
DSL connection problem December 15, 2005, 10:57 am
Why is my connection breaking!?! July 16, 2005, 10:05 pm
Verizon DSL Connection Became Slow October 21, 2004, 7:49 am
Problem with network connection November 9, 2004, 7:53 pm
SBC DSL Connection Problem and Solution August 22, 2005, 8:23 pm
Multiple broadband connection? September 28, 2005, 7:56 pm
Multiple broadband connection? October 3, 2005, 6:44 pm
Problems with Verizon DSL and VPN connection June 22, 2006, 4:24 pm
internet connection loss December 14, 2007, 12:58 pm
DSL connection history logger? August 22, 2006, 3:46 pm
Wil I gain anything by tweaking my DSL connection? May 21, 2008, 1:56 pm
