Digital Subscriber Line DSL Router Splitter question
Subject Author Date
DSL Router Splitter question hotister 07-29-06
Posted by on July 29, 2006, 2:35 pm
Hi all, just a quick question. We are using Yahoo/SBC DSL and we
already setup a DSL router without any problem. However, in the house,
we have a downstair family room which we wired just ONE network cable
to the room so it could only connect to ONE PC, but right now we just
setup another PC in that family room, and we want to make the 2nd PC to
be able to connect to the Internet as well. But it's really a long
distance and a lot of trouble to rewire another network cable from our
upstair living room to downstair family room. Is there any way that TWO
PC could share with ONE network cable to allow both PC to be able to
connect to the Internet. We don't want to use wireless network as the
signal is kind of weak. As the two PC in the family room is kind of
close to each other, could I add another NIC in both PC and network
these two PC and let them share Internet connection this way?? Many
thanks!
Posted by Gene S. Berkowitz on July 29, 2006, 3:17 pm
hotister@hotmail.com says...
> thanks!
What you need is called a "hub". It is an inexpensive box that allows
one ethernet connection be expanded to multiple ports. Hubs typically
can have from 4 to 32 ports. Plug the existing network cable into the
hub (there is usually a dedicated jack for the "uplink").
Both PCs willrequire a network card and ethernet cable.
Plug each PC into the other hub jacks. Your current router will hand
out a different IP address to the new PC. The router never sees the
hub, it is there to allow the ethernet signal to be shared without
degrading.
If your router and network cabling supports 100BaseT, buy a 10/100BaseT
hub. Otherwise, you can get a 10BaseT hub for next to nothing.
Read more at:
http://en.wikipedia.org/wiki/Ethernet_hub
--Gene
Posted by David H. Lipman on July 29, 2006, 6:11 pm
| thanks!
The technical terms for a devices that fan out one twisted pair Ethernet cable
to multiple
Ethernet ports are "Ethernet Hubs" and "Ethernet Switches".
You can pick up an Linksys 8 port Ethernet Switch for ~$50.00 US. Hubs are not
as good as
Ethernet Switches (I'm not going to get into the technical reasons why) but they
are common
and cost even less. In either case you can then hook up multiple computers or
Game Boxes
such as the XBox and PlayStation/2.
Dave
http://www.claymania.com/removal-trojan-adware.html
http://www.ik-cs.com/got-a-virus.htm
Posted by Robert Redelmeier on August 1, 2006, 2:56 pm
hotister@hotmail.com wrote in part:
> house, we have a downstair family room which we wired just ONE
> network cable to the room so it could only connect to ONE PC,
> but right now we just setup another PC in that family room, and
> we want to make the 2nd PC to be able to connect to the Internet
> as well. But it's really a long distance and a lot of trouble
> to rewire another network cable from our upstair living room to
> downstair family room. Is there any way that TWO PC could share
> with ONE network cable to allow both PC to be able to connect to
> the Internet. We don't want to use wireless network as the signal
> is kind of weak. As the two PC in the family room is kind of close
> to each other, could I add another NIC in both PC and network these
> two PC and let them share Internet connection this way?? Many thanks!
There are at least four ways you can do this:
1) break-out boxes which use two pairs (of the Cat5 cable) for each computer.
They are passive, but usually have to be custom made.
2) MS-Windows "Internet Connection Sharing" over a serial or parallel
null modem cable.
3) An active hub or switch in the family room as others have suggested.
This is probably the easiest, off-the-shelf, but does require power.
4) Re-cast the network topography. Move DSL modem & router to family room,
send connectivity back upstairs. This requires phone & power.
-- Robert
Posted by on August 20, 2006, 3:32 pm
These are actually quite common and available off-the-shelf from any decent
hardware shop. They are also easily the cheapest solution.
Go to http://www.unicomlink.com/products/cables_adapters/splitters.asp and
look at the bottom half of the page for some examples.
Billy Y..
Similar ThreadsPosted
DSL Router Splitter question July 29, 2006, 2:35 pm
NEW Dsl splitter technical question March 25, 2005, 6:58 pm
DSL splitter technical question March 22, 2005, 8:38 am
Pinging my router from the outside, a PPPOE question. January 21, 2007, 8:29 am
Linksys BEFSR41 Router question. July 13, 2005, 12:16 am
Re: PPPoE in DSL modem/router (novice question) November 6, 2007, 6:53 pm
Question about Speedstream 5100 modem and router combo January 21, 2005, 12:58 pm
no splitter? July 8, 2005, 7:31 pm
SBC - do I need a tech install to get a splitter? December 15, 2005, 7:40 pm
Looking for ADSL Splitter Module June 16, 2007, 2:11 pm
DSL problems with amplification (installing indoor splitter) September 23, 2004, 4:19 pm
Changing from room filters to a splitter - info? November 9, 2004, 9:01 am
Phone use kills DSL connection, even with whole-house splitter September 24, 2005, 10:30 pm
Semi-OT: Piggybacking a WiFi router onto existing FireWall router? November 15, 2005, 9:58 am
ADSL Modem with a Built-in Router? Can I connect another router to it? March 26, 2007, 2:41 am
