Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on February 27, 2007, 10:46 pm
Please log in for more thread options Hi, I need to setup a DHCP/Bridged Ethernet connection on my ADSL modem. I know the correct VPI/VCI value to be used for this but I'm not sure if LLCSNAP or VCMux should be used as encapsulation. I have configured my modem using both encapsulation methods just to be sure, however I cannot get an IP address in either configuration (LLCSNAP or VCMux). Are there other compatibility issues or configurations that I need to check with my ISP/DSL provider? Also, my modem supports RFC-2684 Bridged Ethernet. Will it be an issue if the provider uses RFC-1483 Bridged Ethernet? Thanks, Ennui | |||||||||||||
Posted by Tony on February 28, 2007, 1:11 am
Please log in for more thread options Just use the default values and RFC-1483 Bridged Ethernet. Smith Falls may become an oasis in the desert. en.nui@hotmail.com wrote: | |||||||||||||
Posted by on February 28, 2007, 1:25 am
Hi, The default values don't work. I did not get the modem from DSL/ISP provider. Can it be that the "bridged ethernet" implementation of my modem is not compatible with the provider's implementation? Thanks, ennui Ayon kay Tony: > Just use the default values and RFC-1483 Bridged Ethernet. Smith Falls may
> become an oasis in the desert. > > en.nui@hotmail.com wrote: > > > Hi,
> > > > I need to setup a DHCP/Bridged Ethernet connection on my ADSL modem. > > I know the correct VPI/VCI value to be used for this but I'm not sure > > if LLCSNAP or VCMux should be used as encapsulation. > > I have configured my modem using both encapsulation methods just to be > > sure, however I cannot get an IP address in either configuration > > (LLCSNAP or VCMux). > > > > Are there other compatibility issues or configurations that I need to > > check with my ISP/DSL provider? > > > > Also, my modem supports RFC-2684 Bridged Ethernet. Will it be an issue > > if the provider uses RFC-1483 Bridged Ethernet? > > > > Thanks, > > Ennui | |||||||||||||
Posted by Tony on February 28, 2007, 1:29 am
When in doubt flash the modem with United States firmware. Then do a factory reset to shake all the crud out of it's memory. en.nui@hotmail.com wrote: > Hi,
> > The default values don't work. I did not get the modem from DSL/ISP > provider. > > Can it be that the "bridged ethernet" implementation of my modem is > not compatible with the provider's implementation? > > Thanks, > ennui > > Ayon kay Tony: > > Just use the default values and RFC-1483 Bridged Ethernet. Smith Falls may
> > become an oasis in the desert. > > > > en.nui@hotmail.com wrote: > > > > > Hi,
> > > > > > I need to setup a DHCP/Bridged Ethernet connection on my ADSL modem. > > > I know the correct VPI/VCI value to be used for this but I'm not sure > > > if LLCSNAP or VCMux should be used as encapsulation. > > > I have configured my modem using both encapsulation methods just to be > > > sure, however I cannot get an IP address in either configuration > > > (LLCSNAP or VCMux). > > > > > > Are there other compatibility issues or configurations that I need to > > > check with my ISP/DSL provider? > > > > > > Also, my modem supports RFC-2684 Bridged Ethernet. Will it be an issue > > > if the provider uses RFC-1483 Bridged Ethernet? > > > > > > Thanks, > > > Ennui | |||||||||||||
Posted by Tony on February 28, 2007, 1:34 am
I think bellsouth is still giving away free modems. Phone them and get one it probably will work. I think they set them to bridge mode. en.nui@hotmail.com wrote: > Hi,
| Similar Threads | Posted |
| DHCP problem with Bridged Ethernet | February 27, 2007, 10:46 pm |
| docsis_server DHCP problem | September 21, 2005, 9:32 am |
| static + dhcp mix problem | December 27, 2006, 1:15 pm |
| Speak to me of "Bridged Mode" ... | May 3, 2005, 8:23 pm |
| Bridged, routed or IPmapped subnet? | September 6, 2004, 5:06 am |
| Security Holes with bridged PPPoE on 4200 | August 15, 2006, 2:16 am |
| USB to Ethernet connection? | July 25, 2005, 8:14 pm |
| PPPoE and non-ethernet modems | January 17, 2005, 6:53 am |
| DSL Ethernet over power line | July 27, 2005, 9:18 pm |
| Network two computers via USB and ethernet | November 28, 2005, 5:02 pm |
| Use off-the-shelf DSL modems to extend ethernet? | November 24, 2004, 6:12 am |
| Tiscali Ethernet modem setup | May 15, 2005, 10:16 pm |
| Copper Mountain G.Lite with Ethernet | January 16, 2007, 7:29 pm |
| D-Link DSL-502T ethernet and USB ports at same time? | June 22, 2006, 8:41 pm |
| Router used as a WAP/DHCP | January 12, 2005, 12:34 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> (LLCSNAP or VCMux).
> Thanks,
> Ennui
