Digital Subscriber Line Australian-bought ADSL router. Will it work in Europe?
Subject Author Date
Australian-bought ADSL router. Will it work in Europe? meulie 03-04-05
Posted by on March 4, 2005, 3:09 am
Hi all!
The following: a friend of mine has returned from Australia with a
Billion Bipac 5100 ADSL router
(http://www.billion.com/product/adsl/bipac5100.htm). Will this router
function here in Europe (in Norway, to be more specific)?
And if it will, are there any settings that need changing?
Regards,
Evert
Posted by Broadband Techie on March 4, 2005, 11:56 am
Your modem should work fine in Europe, just verify with your ISP the values
of VP/VC (Virtual Path/Virtual Circuit).. The values used by most US
providers are 0/35, but some modems came with default of 8/35...
Good luck
> Hi all!
> Regards,
> Evert
Posted by David H. Lipman on March 4, 2005, 4:24 pm
| Hi all!
| Regards,
| Evert
You have to ask your ISP if it is compatible with their equipment.
Dave
Posted by on March 4, 2005, 9:25 am
So there are no difference in the (ADSL-part of the) telephone systems
in different parts of the world...?
Regards,
Evert
Posted by David H. Lipman on March 4, 2005, 6:29 pm
| Regards,
| Evert
There are different applications of ADSL technology; G.lite, G.DMT, G.test,
G.OAM and G.HS
are just some examples. Like I said, you have to contact the ISP to see what
hardware is
compatible with their application of ADSL.
Dave
Similar ThreadsPosted
Australian-bought ADSL router. Will it work in Europe? March 4, 2005, 3:09 am
I can't get my router to work July 27, 2005, 2:08 am
ADSL Modem with a Built-in Router? Can I connect another router to it? March 26, 2007, 2:41 am
How to connect a router to an ADSL router? January 18, 2005, 6:02 pm
ADSL router getting hot possible ??? June 13, 2005, 8:26 pm
Router ADSL Eth/USB March 3, 2006, 10:20 am
Will DSL work with my phone system? July 17, 2004, 3:28 pm
Getting PPoE to work on a Linksys January 9, 2005, 1:06 pm
help needed with adsl router & connections September 17, 2005, 6:20 pm
Speed Touch 330 now fails to work?? September 13, 2005, 6:37 pm
can netgear gd834g work with cable isp? January 26, 2006, 8:06 pm
Does the Actiontec GT701 work on a CAP circuit? April 22, 2006, 7:43 pm
STOP what you’re doing - It doesn’t work! 5YWX July 29, 2006, 1:34 pm
ADSL modem > router - IP address confusion November 27, 2004, 2:14 am
International firmware for ADSL modem/router February 14, 2006, 3:37 pm
