Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on October 8, 2007, 12:22 pm
Please log in for more thread options with configuring it, and have a spare 5 minutes or so, perhaps you could run a quick test. I am having a problem with my GT704 and feel that it is inherent in the firmware and not a defect of my particular router but I cannot be 100% certain. I have found that if I set up the router in DHCP configuration, but specify what DNS servers should be issued to the clients (static rather than dynamic), the modem still continues to issue its own LAN IP address and the local ISP DNS server IP address rather than the IP addresses that I have specified. I would like to know if this the case for all GT704s or only mine. In order to run the test you must first configure the GT704 to use two DNS servers that are not associated with your ISP. A good set of instructions, if you are not familiar with the procedure or do not know of two DNS servers to use, can be found at https://www.opendns.com/start?device=actiontec-gt704 . After you have rebooted the GT704 and confirmed that IP addresses you entered have been saved, one way of determining what DNS server IP addresses are being issued to your Windows XP client (assuming it is using DHCP to obtain an IP address and DNS server information) is to open up a command prompt and issue the command "IPCONFIG /renew" followed by the command "IPCONFIG /all". The DNS servers listed by the second command should show the addresses you configured the GT704 to issue. I would be curious if that was the case, or if it continues to issue the LAN IP address of the GT704 (probably a 192.168.xxx.xxx address) and your local ISP DNS server IP address. After the test you can repeat the configuration procedure but select dynamic rather than static to return your GT704 to its original configuration. Thanks for your help. | ||||||||||||||||
Posted by T. Keating on November 30, 2007, 10:12 am
Please log in for more thread options The GT-704 dns functions is broken big time.. They've known about the issue for a long time.. (2yrs?) Same goes for those turkeys @ TI , who shipped the broken reference firmware to the OEMs. The internal dproxy program, eventually runs out of file handles(1024) in the limited busybox, (linux 2.4.17 ramonly), environment and either hangs or crashes in a couple of days. Do not use it.. I recommend pointing all of your PC dns entries to your ISP's DNS IP addresses.. and kill off the dproxy process by telneting into the GT-704.. Log in as 'admin'.... Password.. "your web password" and type kill -9 `pidoff dproxy`.. and then exit. If you run servers behind this DSLmodem/gateway.. I also recommend doing the following.. before logging out. cd /proc/sys/net/ip4/netfilter echo 1800 > *close_wait
echo 3600 > *established Which prevents /proc/net/ip_conntrack (NAT function) table overflow when someone lunches a spoof attack. Note: Each time you reboot/power cycle.. all of these configuration settings are lost. If you need to retrain/reset the DSL connection, simply disconnect the phone line connection for a second or two. >
>I have found that if I set up the router in DHCP configuration, but >specify what DNS servers should be issued to the clients (static >rather than dynamic), the modem still continues to issue its own LAN >IP address and the local ISP DNS server IP address rather than the IP >addresses >that I have specified. I would like to know if this the case for all >GT704s or only mine. Actiontec has posted only one firmware.. 3.0.1.6.0- GT704 for the unit.. All of them suffer from the same problem. Actiontec tech support is virtually non-existant. Note: 3rd party OEM's like Quest may have fixed these bugs in the versions they ship to their customers. >
>In order to run the test you must first configure the GT704 to use two >DNS servers that are not associated with your ISP. A good set of >instructions, if you are not familiar with the procedure or do not >know of two DNS servers to use, can be found at >https://www.opendns.com/start?device=actiontec-gt704 . > >After you have rebooted the GT704 and confirmed that IP addresses you >entered have been saved, one way of determining what DNS server IP >addresses are being issued to your Windows XP client (assuming it is >using DHCP to obtain an IP address and DNS server information) is to >open up a command prompt and issue the command "IPCONFIG /renew" >followed by the command "IPCONFIG /all". The DNS servers listed by >the second command should show the addresses you configured the GT704 >to issue. I would be curious if that was the case, or if it continues >to issue the LAN IP address of the GT704 (probably a 192.168.xxx.xxx >address) and your local ISP DNS server IP address. > >After the test you can repeat the configuration procedure but select >dynamic rather than static to return your GT704 to its original >configuration. Thanks for your help. | ||||||||||||||||
| Similar Threads | Posted |
| Actiontec GT704 and DNS | October 8, 2007, 12:22 pm |
| Actiontec GT701-WG Lockups | January 23, 2005, 12:41 am |
| Actiontec + DSL + NEtgear VPN firewall | June 12, 2007, 9:31 am |
| Actiontec GT-701WG Error Logs | April 13, 2005, 1:45 am |
| Does the Actiontec GT701 work on a CAP circuit? | April 22, 2006, 7:43 pm |
| Qwest reverted to old Actiontec firmware on their Web site | September 1, 2006, 9:59 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
