I finally got my WLAN setup operating today with the arrival of my V5 WRT54G. BTW, it came with 1.00 f/w but I upgraded to 1.06 just in case. On my thinkpad I have an Atheros mini pci card feeding two 4 element coaxial collinear antennas that are tacked on the back of my screen with hot glue. The Atheros card puts out 100mw and I think the WRT54G puts out 30mw.
Anyways, I went for a walk to do a range check and I got about 1,400 ft before I lost signal due to interference from other WLANs on the same channel & with the same SSID. This was NOT line of sight - I was going through houses & buildings.
I'll repeat the test sometime today now that I'm on a ch that (according to Net Stumbler) nobody else is using in my area and I now have a unique SSID.
Now - on to my questions:
1) Is it me or is 1,400' above average range for WiFI? 2) I googled and read that WEP is not 100% secure so I switched to WPA Personal TKIP but Net Stumbler still reports that I'm running WEP? I verified several times that I am running WPA. What's up with that? 3) Anyone have a source for RP-TNC connectors that can be used with LMR-400 (.405" dia) coax? I'm gonna build a pair of 16 element collinear antennas and put 'em up my 60' tower -maybe.Thanks for the advice!
