Several months ago, I purchased a "Linksys Wireless G PCI Card with SpeedBooster" (model WMP54GS) for my Windows XP machine running an AMD Athlon XP 2400 and 1 GB RAM. The card installed nicely, however based on the location of the antenna (up against a corner with tons of wires running around it), I couldn't get anything better than a "LOW" connection in the basement suite where I live. So I went out and bought the "Linksys Wireless G USB Network Adapter with SpeedBooster" (Model WUSB54GS) in hopes that I could get a better connection. So I uninstalled all the software associated with the PCI card, and took it out of the computer. Then I did a fresh reboot and installed the USB Adapter. The problem was that every time I plugged it in it would recognize it as an unknown device TWICE. After some fiddling around, I still couldn't get it to detect properly although occasionally I could get an internet connection (when the adapter was detected properly). After uninstalling it and reinstalling it several times, this is where I'm at now:
When I reboot the computer, everything loads up fine except, I get a message in my taskbar stating "No Available Wireless Networks in Range." The problem is not actually that there's no signal in range, it's that the computer won't detect the USB Wireless Adaptor. The ONLY way I have managed to work around this is to:
1) Wait for Windows XP to fully load up 2) Unplug the USN Wireless Adaptor (from the adaptor itself) - I then get the little chime indicating a USB device has been disconnected 3) Wait for several seconds 4) Re plug-in the USB Detector.After doing this, the computer "finds" the USB Wireless Adaptor and then detects and connects to the available wireless network.
This is the ONLY way I can ever get any kind of internet access. Another thing which I'm sure is related is that once I'm up and running, if I go to my Device Manager, under USB Controllers I have:
- USB Composite Device on USB 2.0 Bus (Device Type: Universal Serial Bus controllers, Manufacturer: OWC, Location: Linksys Wireless-G USB Network Adapter with SpeedBooster, and Status: This Device is Working Properly ). This is obviously the adaptor that I have to unplus and re-plug in each time.
But under "Other Devices" I have:
- Device on USB 2.0 Hub (the Device Type, Manufacturer, and Location are all IDENTICAL to the above device, however the status says: This device is not configured correctly. (Code 1) . To reinstall the drivers for this device, click Reinstall Driver.
So it appears that the computer is detecting the same adaptor TWICE. If I uninstall the "Other Device: Device on USB 2.0 Hub" it just redeteccts itself each time.
So what do I need to do so that I can just turn on the computer and have the wireless adaptor and network detected automatically (which it SHOULD be doing anyway).
Any help would be greatly appreciated. I've contacted Linksys and didn't really get anywhere.
Thanks,
Ryan snipped-for-privacy@gmail.com
