sing this combo is there any way to set one of the 4 switch ports to connect to the WAN side instead of the LAN side?
My thought is to get a device plugged into said port to be able to pick up the second IP address I have available without having another switch between the modem and the router.
In other words, router to get 1 IP.. and the other device to get a second IP.. I was thinking somewhere in the VLAN settings it may be possible, but I am not sure.
