I have a linksys WRT54GS V4 router and a WUSB54GS usb wireless network adapter.
I power on the router and connect it with a Cat5 (supplied) to my computer's network card. log in to the router with http://192.168.1.1/ set it up with the SSID & WEP and and it all appears to be working fine.
So I unplug the Cat5 from the router and the computer and plug in a WUSB54GS network adaptor. After everything is set up, WEP, SSID I then try to connect to the router wirelessly and it cannot find a network.
I do a site survey and nothing.
My router is not connected to and ADSL line, it's just powered up. Should I not be able to connect to the router?
Thanks Stephen
