Hi all,
My WRT54GS works fine once it's up and running but if I have to unplug it or restart it, it does not get an IP address from my provider. My older BEFSR41 works fine in the same situation. I can plug in the SR41, get an IP address and then reconnect the WRT54GS and it keeps that IP address. So for some reason the wireless router cannot request an IP address.
Has anyone had this problem?
I'm running v3.37.2 firmware on the WRT54GS.
Thanks,
Kevin
