Thanks in advance for any help. I currently use a WRT54GS as a wireless router. I have 2 PC's that are in rooms connected by wire and would like to move the WRT54GS to the other computer. I bought a BEFSR41 to use as the "primary" router connected to my cable modem. I have found instructions on converting my wireless router to act as WAP, but I'm a little confused. After converting the WRT54GS, can I move it to to second room and run the cable from the wall into the router and then another cable from the converted router to the second PC? Basically I want the 2 PC's wired to the BEFSR41, but have the WRT54GS in the room with the second PC. Thanks very much.
- posted
16 years ago
