WRT54G Version 5 WDS?
Since Sveasoft does not support WRT54G Version 5 how does one enable WDS on this device?
TIA, Dan
Dan
Dan hath wroth:
By selling it and buying one that supports alternative firmware. There's nothing that can be done with a WRT54Gv5 because it's totally different hardware and does not run Linux.
Jeff Liebermann
Which has the best coverage and how does it compare to the WRT54G: Buffalotech WBR2-G54 or Belkin F5D7230-4? Is Sveasoft WPA supported on the Belkin?
Dan
Dan hath wroth:
I have no experience with either device and cannot offer any comparisons. A bit of Googling shows that the both can handle DD-WRT and Sveasoft firmware:
would expect that the coverage would be identical to the WRT54G as the chipsets used and specifications appear to be identical. For details, methinks you should ask the same question on the Sveasoft or DD-WRT forums.
Yes. WPA is in Satori and Talisman.
Jeff Liebermann
