Hi all,
I wonder if anyone can help me with a setup problem I am having?
I have the following setup?.
I have a static IP 194.xx.xx.xx and have an asus ADSL modem that provides broadband to my fixed line network of PCS via a 4 port hub. This setup has been working fine for a number of years.
I have my new WRT54G and I want to put it on the network. I have tried to put it on the network by taking a line from the 4 port hub into the ?internet' port of the WRT54G and plugging in a PC into one of the 4 other ports on the WRT54G. I can ping the WRT54G from the PC on
192.168.1.1 and get into the web interface. I have my PC LAN connection setup as per instructions to DHCP and the PC has been given an address of 192.168.1.100 as expected. All looks fineHowever I'm unsure as to how I can get ?internet' access on the PC, and what settings I put in the ?setup' page for the WRT54G? Should I be using DHCP configuration? Or static IP? If so,What should I have for IP, subnet, gateway and DNS?
The ASUS modem has it's own IP of 192.168.80.1. I can't ping that from the PC through the WRT54G, (I could previously in the original setup).
Any help greatly appreciated.
