WRT54G as repeater
A good place to learn more about the Linksys WRT54G is
Go to the forums. Rick
Rick Ankrum
Does anybody know how to do this or is there a web page out there that tells you how? I've seen it mentioned on web discussion boards.
I recently got a D-Link wireless router and the signal is better than the WRT54G. However I'd like to be able to use the WRT54G on the top floor of my townhouse.
TheMachineRNC
Well.... I downloaded the firmware and it nuked my router. The diag light keeps blinking. I've done a hard reset and it keeps happening.
Anybody know of a way to fix it? I downloaded the L>> Does anybody know how to do this or is there a web page out there that
TheMachineRNC
Fixed it.
Time to try again!
Fingers are crossed.
TheMachineRNC
Try holding down the reset button while powering on and hold it down for
30 seconds or so. That should do a proper hard reset.
Failing that, go and have a look on the sveasoft forums at
as this sort of thing is a not uncommon event when flashing with their firmware.
When my diag light kept flashing, I had to recover by soldering in the connector to the JTAG port on the router (open case required), then short out the flash ram with a bit of wire while powering on. Then upload a new loader from the PC via the parallel port (cable making required).
Then the router reboots with a default IP address and waits for a new firmware to be uploaded via tftp.
Loads of fun!
David.
David Taylor
Well done, you obviously had the half bricked router instead of the fully bricked job. :)
David.
David Taylor
