Can I use a WRT54GS with stock linksys firmware as AP with just connecting a network cable to one of the LAN ports and assign a static LAN IP? I don't want any routing, just to extend a cabled network a bit.
If yes, which 'Internet connection type' do I select (if it does matter at all as I don't use the WAN port).
Finally, can I run a WRT54GS with stock linksys fw also as wireless client to the above AP?
thanks for comments ;-)
Geir
