WRT54G and disconnects
Threaded View
Initially, I thought it was me or my ISP.
Every day or otherday, I have to do a DHCP release and renew on the Linksys
and then a ipconfig /release and /renew on my client to restore the
connection.
But after reading here it seems it might actually be the Linksys box that is
the issue.
Anywhere I could look? Or any other suggestions as to another manufacture's
wireless router I could install to test this theory?
Bryce.
Re: WRT54G and disconnects
get custom firmware from www.linksysinfo.org or www.sveasoft.com
(recommended but costs 20$)
change the MTU to 1400
RTS Threshold to 2304
Beacon Delay to 200
THis fixed the same problem that you have.
Linksys firmware sucks.
I put the hyperwrt firmware on it.
Was that not a good one?
I'll check out those settings tonight. Thanks.
The Alchemy v1.0 firmware from Sveasoft is significantly more
developed than HyperWRT.  You might want to try it for
comparison.
I'm hard pressed to see what any of them other than the
MTU might do to improve things.  Changing the MTU will
help reduce fragmentation of large packets by the facilities
you use to connect to the Internet (a cable or xDSL modem).
Some of them hang if the MTU is the default 1500 for ethernet
(because an extra header gets added, which means every full
sized packet has to be split into one big one and one small one,
and some units fail when they try).
Floyd L. Davidson           <http://web.newsguy.com/floyd_davidson
Ukpeagvik (Barrow, Alaska)                         floyd@barrow.com
could you steer me in the right direction on that site for the exact file
I'm supposed to download?
Do I just update the firmware like I did with the hyperwrt?
Bryce.
Firmware dowloads for WRT54G(S) [was Re: WRT54G and disconnects]
Yep, same process.
Just to get this all into the Usenet archives so that others can
stumble across it on google, I'm going to give a *detailed* list
of the various packages available at <http://www.linksysinfo.org/ .
(Other sites were several of these packages are available are
<http://firmware.carlsonwebdesigns.com/ and <www.wrt54G.com>.)
You have to register for a free user account, and then log in
and click on the download button.  That will get a list of
products, and if you scroll down there is one for "WRT54G and
WRT54GS".  Clicking on that brings up a page with the latest
Linksys beta firmware at the bottom of the page, and with a list
of links to several third party downloads.
These are the variations available, with comments from the
linksysinfo.org site that are obviously most are written by the
PR team for each product, some of which I've trimmed.
I've added my comments at the end of the list, and some at the
end of a particular entry [which are enclosed in square brackets
like this to mark them as mine]
  LINKSYS        http://www.linksys.com /
     WRT54GSV2.1_4.05.5_US_code.bin
        Beta for the WRT54GS
        Version: v4.05.05
        Filesize: 2.94 MB
     WRT54GV3.1_4.00.5_US_code.bin
        Beta for the WRT54G
        Version: v4.50.05
        Filesize: 2.74 MB
     WRT54GV3.1_4.00.7_US_high.code.bin
        Beta for the WRT54G
        Version: 4.00.7
        Filesize: 2.74 MB
        This seems to help fix throughput and disconnection
        problems with the newer v2.2 - v3.0 wrt54g routers. this
        firmware has a overlcoked rate 240-250 mhz.
     [Linksys of course also has the older version available on
     their web site, plus they also have an entire development
     package, source code and all.]
    DD-WRT          http://www.dd-wrt.com /
        DD-WRT v22prefinal 3.2
        Beta for the WRT54G and WRT54GS
        Version 2.2pre3.2
        Filesize: 3.36 MB
        Created from the Sveasoft Alchemy 5.4a Source Code.
        Includes Extra Features that Alchemy Lacks.
        Fixes Include:
             site survey fixed
             wrt-radauth enhanced with portal function
                for unauthorized users
             wds-watchdog nvram initialisation fixed
             various web bugs fixed (thx Cesar)
  [On another page the author of this distribution says it has
  an enhanced interface for a RADIUS authetication system, and
  can mount samba shares from a Microsoft box, thus making it
  more suitable for those who do not have a Linux background.
  DD-WRT V22-prefinal4 (Talismen) is available at  www.dd-wrt.com.]
      EWRT          http://www.portless.net/menu/ewrt /
        Version: v0.3 beta
        Filesize: 2.85 MB
        Ewrt is the Enhanced WRT linux distribution
        # Based on the Linksys 3.01.3 codebase
            * Support for all WRT54G and WRT54GS hardware
            * Greatly improved QoS, including hardware QoS
                support on newer models
            * Config backup/restore functionality
            * Wireless client isolation functionality
        # Imported Dropbear 0.44, now we have working ssh
            and scp clients
        # Imported Busybox 1.00 which greatly improves the
            Unix userland
        # Upgraded NoCatSplash to version 0.92
        # Upgraded Squashfs to version 2.1-r2
        # Created a writeable jffs2 filesystem on /opr using
            free flash space (credits to the OpenWRT project)
        Source code for the firmware can be obtained at the
        owners website.
        The goal of the project is to maintain a stable and
        secure platform for use in enterprise and wireless ISP
        environments...
        [also see  http://firmware.carlsonwebdesigns.com/Ewrt /]
  Freifunk   www.freifunk.net/wiki/FreifunkFirmwareEnglish
        [Nothing shows up on this one at www.linksysinfo.org,
        but there is an English web page at the URL above.]
  HyperWRT       www.hyperwrt.org
        For the WRT54G v1.0-3.0
        HyperWRT 2.1b1 WRT54G
        Version: 2.1b1
        Filesize: 3.23 MB
        For the  WRT54GS v1.0-2.0
        HyperWRT 2.1b1 WRT54GS
        Version: 2.1b1
        Filesize: 3.47 MB
        HyperWRT has these added features :
          Adjustable Transmit Power & Antenna Select
          13 Wireless Channels
          ''Boot Wait'' flash protection
          Increased maximum concurrent connections
          More Port Forwarding & Triggering Fields
          More Qos Device & Application Fields
          More Access Restrictions Policies & Blocked Services Fields
          Command Shell
          Telnet Daemon
          Startup & Firewall Scripts
          Uptime
       The goal of this project is to only add a limited set of
       fixes to make the official firmware useful for most
       people.
       owners website.
   OpenWRT         www.openwrt.org
        [Nothing shows up on this one at linksysinfo.org.
        See http://openwrt.org , however the archive is down.
        A message says the latest release was updated on April,
        24, 2005 though.]
        "OpenWrt provides only a minimal firmware with support
        for add-on packages."
  Sveasoft         www.sveasoft.com
     Alchemy Project
        For the WRT54G V1.0 - V2.2 and WRT54GS v1.0, v1.1
        Alchemy v1.0 Final
        Version: v1.0
        Filesize: 3.41 MB
        Looks like WRT54G v3.0 and WRT54GS v2.0 are NOT supported
        however some users of v3.0's are reporting it does work.
     Satori Project
        For the WRT54G v1.0, v1.1, v2.0 and WRT54GS v1.0
        Sveasoft Satori v4.0
        Version: 4.0
        Filesize: 2.59 MB
        Auto channel select option
        AP Watchdog timer option
        New Management page help (thanks to Markus Baertschi)
        SSH DSS keys now supported (thanks to Rod Whitby)
        NTP remote server field lengthened
        Old port forwarding format supported
        PPTP server fixed
        webstr iptables filter fixed
        adm6996 module moved
        ifconfig broadcast addresses fixed
        local dns fixed
        Remote syslog fixed
        rc_startup and rc_firewall fixes
        Missing files and directories updated
        OpenSSL is not in this build.
        Compatible with both G and GS models
        Linksys "AfterBurner" drivers with DMA
        Default gateway for LAN ports
        Advanced Routing, OSPF, BGP Routing
        Power mode selection
        Antenna selection
        Client mode (Ethernet bridging)
        Adhoc mode
        WDS peer-to-peer networking (10 links, multiple options)
        Modified to forward to any IP address
        Bandwidth Management
        Boot Wait, Cron, DHCP with static MAC->IP assignments
        DNS Masq, Firewall control, Loopback option, NAS
        NTP Client, PPP, PPTP VPN server, Resetbutton daemon
        SSHD with public key or password login
        Shorewall firewall, Syslog with remote logging
        Telnet, Tftp
        Command Shell replaces ping and traceroute
        Linux shell scripts rc_startup and rc_shutdown
           settable from the web
        Wireless signal strengths for clients, AP's, WDS links
        Static DHCP leases
        Added approximately 20 iptables filters
          - include P2P, connection tracking
        Added Quality of Service (for bandwidth mgmt)
        Rewrote networking code for better stability
        Added wireless connections daemon for client mode and WDS
        Added PPTP client and server
        ADM6996 /proc interface
     Documentation
        sveasoftdocwrt54g.pdf
        Version: 1.0
        Filesize: 785.79 Kb
        Sveasoft documentation for early Satori/Samadhi2 firmware.
  TinyPEAP        www.tinypeap.com
        For the WRT54G  v1.x v2.0 (not for v.2.2 or v.30)
        TinyPEAP 2.12b
        Version: 2.12 beta
        Filesize: 3.08 MB
        For the WRT54GS  (not for v1.1 or v2.0)
        TinyPEAP 2.12b
        Version: 2.12 beta
        Filesize: 3.08 MB
        tinyPEAP is a very small RADIUS server that supports
        PEAP authentication (the most secure wireless
        authentication protocol) ...  designed from scratch to
        run on very minimal hardware, such as the Linksys
        WRT54G.  ... allows you to have all of the benefits of
        802.1X and PEAP security without the hassle of having a
        full blow RADIUS server on hand.  ... 802.1X/PEAP
        solutions such as tinyPEAP successfully mitigate most of
        the known attacks against 802.11 wireless networks, most
        notably sniffing and key cracking. The tinyPEAP ..
        integrated this server into WRT54G and GS firmware ...
        with a graphical interface in order to manage the
        server.
  Wifi-Box        sourceforge.net/projects/wifi-box/
        For the WRT54G
        Wiifi-Box v2.02.2.1 pre-wfb
        Version: 2.02.2.1
        Filesize: 3.22 MB
        . Power Transmit Ajusting
          (12.75dBm ~19mW -> max 19.25dBm ~ 84mW)
        . TX & RW Antenna Selection
          (Left Diversity Right)
        . Support for 14 Channels
          (WorldWide)
        . Support for subnet 255.255.0.0 & 255.0.0.0
        . Static DHCP / DNS Local
        . SNMPD ( Works right with mrtg)
        . Support VPN Passthrough (IPSec - PPTP - L2TP )
        . Add 'Server Profiles' for easy configure
          up to 14 Host Servers
        (FTP,HTTP,HTTPS,DNS,SMTP,POP3,Telnet,IPSec,PPTP,
        Terminal,VNC,Emule,Ident,MSN)
        . Up to 14 Port Range Forward settings
        . VPN Server (PPTP) Buld-in
        . Support for Zone-Edit, Custom Dyndns DDNS
        . Telnet Shell
        . Remote Wake On Lan support
        . Easy Reboot and Restart all service just a click
        . Ping & Traceroute hacked for allow run shell command
        . AutoRun Bash Script - Easy set an autorun script
          each time router reboot
        . Status with more infos like Uptime & CPU Load,
          Wireless Client List
        + no SSH Shell
        + no Bandwidth Management
        + no VPN Server IPSec
        + no VPN Client (PPTP & IPSec)
        + no support for Bridge and Repeater, WDS mode
        Linux Kernel 2.4.20 Tweaked
        owners website.
All of the above have a binary only file available, and on their
own web pages have source code too.  The Sveasoft Alchemy
project source code is 42Mb, and I would assume that all of the
others are similar in size.  To actually use a source code
package (other than as a great reference manual) you also need
1) a Linux development system, 2) the Linksys cross compiler and
tools software (something like 170Mb, available on the Linksys
web site).
I've only tried Satori, Alchemy, HyperWRT, and two versions (not
the latest) from Linksys.  Clearly Alchemy is the most advanced
of them all. But there are interesting aspects of the others
too.  The small RADIUS server running on TinyPEAP sounds very
interesting.  Wifi-Box has a lot of stuff if you don't need the
missing parts, and the same is true of HyperWRT and EWRT.
Only DD-WRT mentioned a "site survey", though Alchemy has a web
based survey on the status page that works nicely.  I thought it
was almost cool when I first saw it, because I have a shell
script that does the same thing on the command line.  Then I saw
the source code and realized they had wasted a huge amount of
space with a program written in C to do what can be done with
only a few lines of shell scripting... :-)
Everyone has different needs; hence people like myself with
fewer security requirements can deal with almost any of those
packages.  The advanced firewall and vlan configuration features
in Alchemy are probably *essential* to commercial projects, as
is the dropbear SSH software that some do and some don't have.
What I found lacking in both Sveasoft's Alchemy and Satori were
good command line facilities, all of which were easy enough to
add (for Sveasoft or anyone else willing to recompile it, but
they are non-trivial for non-programmers).  The one operational
functionality that was grossly lacking was the ability to NFS
mount a remote filesystem.  The value in having gigabytes of
disk available instead of needing to cram everything into 16 Mb
of RAM (or the 32 Mb on the WRT54GS models) is significant.
One other note...  the hardware.  There is a *lot* that can be
done with the hardware on that little board.  But messing with
it is risky business because one mistake that kills all network
access makes it a doorstop.  Reloading firmware can still probably
be done, but it all gets to be painful.  The solution, for anyone
wanting to experiment with the 6 port switch is to put an RS232
console on it!  There is one RS232 port fully equipped and wired
to a solder pad on the motherboard...   and there is an EJTAG
port for serious debugging.
Re: Firmware dowloads for WRT54G(S) [was Re: WRT54G and disconnects]
So what I gleam from this is:
Either I can fix the disconnect problem with the
OR
I can use one of the other ones to increase my power output and add some
goodies.
But I can't do both.
Am I on the right track?
Bryce.
I don't know... :-)
If the list of added goodies contains something of use (and I
personally don't think increasing the power is significant),
then the third party software is certainly the way to go.  For
me that is obviously true, because I just want to play with the
innards of these things...
But if you don't have any need for the added functions in third
party firmware, you may as well stick with Linksys.
So pick out the ones that appear to be useful, and read up on
what they say their firmware provides.
Or maybe download one and try it just for fun...
Thanks!
Floyd. Thanks so much!
Bryce.
You are certainly welcome, and it turns out to have been well
worth the effort, for me too.
The DD-WRT distribution perked my interest, so I took a closer
look today.  Seems I've underrated its state of development.
The linksysinfo.org description is out of date, and the current
DD-WRT project's release is v22prefinal4, which is based on
Sveasoft's latest Talisman version, rather than the older
Alchemy based v22prefinal3.2.
At a minimum DD-WRT is keeping up with Sveasoft, and may be
ahead of them in at least some respects.
It got me interested enough to download their source code, which
is not trivial with a 45kbps modem connection!  At the moment
I'm 38.5 Mb into a 90 Mb download that started 3 1/2 hours ago.
I'm about to head for dinner, and probably before morning will
have at least tried it, assuming the download does complete and
that it will compile using the tools I have now.  And whether it
will or not, they have another 100Mb download that is something
about upgraded tools, which will take another 10 hours to
download.
It should be interesting, but will take a few days to see if
switching from the code base I'm using now is worth it or not.
Linksys
that is
manufacture's
 I have a wrt54g and if I use the WZC in windows it works fine, If I
use
a wireless utility it doesnt get the IP until I do what you do.  Go
figure.
Site Timeline
