Wireless Networking wrt54 antennas
Subject Author Date
wrt54 antennas jimmie68 07-22-08
---> Re: wrt54 antennas Jeff Liebermann07-22-08
Posted by on July 22, 2008, 2:41 pm
IS there a distinction between the two antenna connectiond on the
WRT54 wireless routers. I had heard that one is for TX and the other
for RX but my router seems to work equally well with either antenna
disconnected. I cant tell a difference in performance unless I take
them both off.
Jimmie
Posted by Jeff Liebermann on July 22, 2008, 3:53 pm
No. The antennas area identical. However, the two ports are slightly
different. One is designated as "main" while the other is "aux". The
router will normally favor the "main" antenna and only switch to the
"aux" if the diversity receive algorithm determins that the "aux"
antenna has a better signal.
Unfortunately, I can't recall which is antenna is main or aux, or for
that matter, which antenna is considered "left" or "right". Sigh.
Looking at the inside photos at:
<http://www.linksysinfo.org/forums/showthread.php?t=47124>
I would *GUESS*(tm) that the antenna port with the long coax cable
running across the board would be the "aux".
>them both off.
Some routers will only transmit on one antenna (i.e 2-wire). Routers
that have two antennas invariably use diversity receive and sorta
"scan" between the two antennas in receive. I vaguely recall that the
WRT54 transmits on the same antenna that it receives.
However, you should be able to tell the difference with only one
antenna attached. If you remove the antenna from the "main" port, the
stupid firmware will continue to favor the "main" port, even though
there's no antenna or signal. If you ping the router, you'll probably
find that the first ping will be lost using just the "aux" antenna.
That's not the case using only the main antenna.
If you insist on using only one antennna (a good idea if you're
attaching external antennas), some alternative firmwares have a means
of disarming the diversity switch system and just using one antenna.
Start reading here:
<http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008019f646.shtml>
especially the part about the golf course and using two different
types of antennas.
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Posted by on July 22, 2008, 6:27 pm
> No. =A0The antennas area identical. =A0However, the two ports are slightl=
y
> different. =A0One is designated as "main" while the other is "aux". =A0Th=
e
> that matter, which antenna is considered "left" or "right". =A0Sigh.
> <http://www.linksysinfo.org/forums/showthread.php?t=3D47124>
> >them both off.
> Some routers will only transmit on one antenna (i.e 2-wire). =A0Routers
> "scan" between the two antennas in receive. =A0I vaguely recall that the
> antenna attached. =A0If you remove the antenna from the "main" port, the
> there's no antenna or signal. =A0If you ping the router, you'll probably
> Start reading here:
> <http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note091...=
> types of antennas.
> Jeff Liebermann =A0 =A0 je...@cruzio.com
> 150 Felker St #D =A0 =A0http://www.LearnByDestroying.com
> Santa Cruz CA 95060http://802.11junk.com
> Skype: JeffLiebermann =A0 =A0 AE6KS =A0 =A0831-336-2558
Thanks Jeff, I am guessing that the traces on the board may form a
type of diplexer. If this is the case leaving one antenna disconnected
and the port unterminated would defeat the operation of the diplexer.
In this case one antenna connected to one port would work as well as
connecting it to the other. This would explain my experience of having
the unit work equally well with 1 antenna on either port. Having 1 or
2 antennas woud probably make little difference if ther is not a
multipath issue
Jimmie..
Posted by Jeff Liebermann on July 23, 2008, 12:58 am
>type of diplexer.
Nope. It's a diversity switch. If you look carefully, there's a 6
lead chip sitting at the junction of the two i/o ports. The chip does
the switching.
Not exactly. The port with the long coax cable (aux) has a bit of
extra loss in the cable and exhibits perhaps 0.5dB more loss. Not
worth worrying about unless you're trying to squeeze every last dB out
of the system.
>multipath issue
Read the Cisco article. The problem is when you have two different
types of antennas. It's quite possible that the wrong antenna will
hear the signal first. The diversity algorithm doesn't continuously
test for the best signal. If it hears something on the FIRST antenna
that hears a signal, it could easily just sit there forever. The only
justification for switching antennas is if there is a signal loss, or
a rather high bit error rate. If you're planning to use just one
antenna, you should disable the diversity switch in firmware.
Posted by on July 26, 2008, 2:02 pm
> >type of diplexer.
> Nope. =A0It's a diversity switch. =A0If you look carefully, there's a 6
> lead chip sitting at the junction of the two i/o ports. =A0The chip does
> the switching.
> >In this case one =A0antenna connected to one port would work as well as
> Not exactly. =A0The port with the long coax cable (aux) has a bit of
> extra loss in the cable and exhibits perhaps 0.5dB more loss. =A0Not
> of the system.
> >multipath issue
> Read the Cisco article. =A0The problem is when you have two different
> types of antennas. =A0It's quite possible that the wrong antenna will
> hear the signal first. =A0The diversity algorithm doesn't continuously
> test for the best signal. =A0If it hears something on the FIRST antenna
> that hears a signal, it could easily just sit there forever. =A0The only
> a rather high bit error rate. =A0If you're planning to use just one
Interesing, this has got me wondering how hard it would be to alter
the software to use the the switch as a T/R switch. My thought is to
use one antenna for Rx with an antenna mounted LNA. I think I need to
check in with the guys over at DD-WRT.
Jimmie
Similar ThreadsPosted
wrt54 antennas July 22, 2008, 2:41 pm
WRT54G Linksys default antennas replace with 7 dbi antennas May 9, 2005, 10:48 pm
WRT54* in mesh October 25, 2007, 7:58 am
wrt54 v1, too much voltage May 23, 2008, 3:04 pm
WRT54 vs WTR54 November 17, 2008, 2:58 pm
Linksys WRT54 G or GS - QOS Question? November 15, 2005, 10:04 pm
non WRT54(g) open firmware? November 27, 2005, 5:36 am
Linksys WRT54 router September 29, 2006, 8:02 am
WRT54 setup script July 30, 2008, 5:16 pm
Reset of Linksys wrt54 g wireless February 20, 2006, 6:11 pm
Linksys ADSL Modem & WRT54 Interop February 9, 2007, 5:57 am
Linksys WRT54-3G Mobile Broadband router and Cingular Sierra 875 3G aircard compatibilty? December 5, 2006, 3:24 pm
Configuring WRT54 as a switch (configure WAN port as a LAN port) November 15, 2005, 1:42 pm
Antennas December 3, 2004, 10:12 pm
What are 2 antennas being used for? July 24, 2006, 3:30 pm
