I've upgraded the router to 6.1.4 and tried to get this working.
Before I bite the bullet and load DD-WRT on it instead, I thought I should post the settings I've tried to make sure I'm not doing anything stupid.
My main router is a Barricade 802.11b. I run it with 128-bit WEP encryption. It's LAN IP is 192.168.2.1 and its DHCP server is enabled, with an address pool from 150-199.
I've set the 850G to "Wireless Bridge" mode. I've assigned it a LAN IP of 192.168.2.3 and gateway = 192.168.2.1. I've set the wireless SSID, channel number, and WEP key to match the Barricade. DHCP server is off. WAN Connection Type is Disabled.
I've hooked 1 PC up the 850 with a static IP 192.168.2.91, gateway =
192.168.2.1.
All of the IP masks are set to 255.255.255.0
On the Barricades config interface, I've taken what it calls its "WLAN MAC address" which is shown in the form NN-NN-NN-NN..etc and entered that MAC address in the 850 as NN:NN:NN:NN...etc. The 850 shows this as "up", but I don't put a lot of faith in that, since I tried entering a totally made up MAC and it reported that as "up" also.
These are the main settings I've changed and have then tried to ping a machine on the Barricade's LAN from the machine connected to the 850 (along with trying to reach the Internet also).
Can't seem to figure out the right recipe for this to work, any ideas?
Thanks!
