OK. If you happen to be using XP Wireless Zero Config, that might be the problem.
Dell Inspiron 8600 w/ Dell minipci 1450 Card and Linksys WRT54GC WinXP
Trying to get WPA2 Personal working between the two.
Dell states that the card can perform WPA2 but the
Currently WPA-PSK w/TKIP works fine but just trying to get WPA2 to work.
My first question is clarification on WPA2. Is WPA2 the same as WPA-PSK with AES encryption?
If I try to setup WPA-PSK w/AES I get a connection and M$ states I have authenticated, but I am unable to ping the router.
If I set it back to TKIP, all works.
Just searching for a solution if possible.
moncho
Yes.
Latest router firmware:1.02.8,
Already have this version. I also have the most recent version of the Dell
1450 driver.I was hoping that would make a difference when I started having the problem. I was bummed when it made no difference.
Thanks, moncho
I put in the update and it started working but then the network connection would drop every 2 minutes.
I found out that the Dell software was causing the problem, shut it off and now all is well with WPA2-PSK.
I feel a little more secure now.
Thanks for the links
moncho
